Problems setting up Belkin wireless G+ mimo modem router/usb network adapter
I have managed to configure the computer to the router i.e all the details required match my network information ect on the computer.
I can't access the web-based management user interface of the router by typing in the number " 192.168.2.1 ". It says there is no internet connection.
  • 1 more comment
  • Brett Duxbury
    Brett Duxbury Apr 30, 2014
    Did you plug a cat5 ethernet patch cable between the p.c. and the router. Until you setup the wi fi in the router you can't connect to it via wireless. Set the ip settings to use a dhcp server on the computer. It will set up the ip address automatically from the routers dhcp server once you directly connect to it.
  • Brett Duxbury
    the ip address is incorrect also for the router. 192.168.0.1 go to dos prompt once directly connected to router and type in ipconfig (and press the enter key) note the default gateway address in the ip listing this should be the router ip address.
  • Brett Duxbury
    this video may be of some insight as I came across it while helping someone else with similar problem.http://www.youtube.com/watch?v=tXAYPPgyy...
I keep losing connection to internet. I have comcast rca modem with belkin wireless g router. HELP???
Posted on Dec 09, 2007
It sounds like the router address is wrong or you are not connected to the network.. Guessing you are using Windows XP or Vista. Go to the DOS prompt (http://www.computerhope.com/issues/chdos.htm) then type ipconfig. This will bring up details on your network (see example below).
IPv4 Address. . . . . . . . . . . : 192.168.0.4
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
You should see default gateway address which is the address of your router ie 192.168.2.1 in your example. If this is not shown you have not connected to your router properly. If it shows a different address use the address shown to try and access your router. HTH
Posted on Nov 14, 2007
SOURCE:
Can a belkin network card f5d7050 work with a belkin g plus mimo router
As MIMO is compatible with all wireless g products there shouldn't be any issues at all....
so some questions:
  • do you have other wireless devices working with the router? if so can you duplicate their settings for this n/w card?
  • have you set security on the router?
  • what are you using to connect to the network the windows interface (assuming it's PC not MAC based) or the Belkin one?
i have a linksys g n/w card attached to my MIMO router & it's fine so I'm sure that this is solvable!
Sep 06, 2010 | Belkin F5D9050 Wireless G Plus MIMO USB...
The wireless network is being picked up by the laptops in the house, but there is no internet connection between the modem and the router. MY router is a Belkin G Wireless
if you connect the computer directly to the modem, does it work?
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 06, 2010 | Belkin Wireless-G Plus MIMO Router with...
How do i connect my verizon dsl westell 6100 to my belkin g rtr?
Wellll....since it seemed an impossible task, I tried the next best thing.
I bought a wireless adapter for the other pc and voila! they are on the internet, and I am returning the router.
Westell modem + Verizon DSL w/usb = No connection to router.
Dec 28, 2009 | Belkin Wireless G Plus MIMO (F5D9010)
No connectivity with the G Plus MIMO Router
Make sure the router is set up to receive an assigned address, probably DHCP. Unplug the modem for about 30 seconds with the router and computer off. Power on the modem. When it comes ready, power on the router. When it comes ready, the laptop.
Aug 27, 2009 | Belkin Wireless G Plus MIMO (F5D9010)
Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a belkin wireless g+mimo router without usb adapter can i install this and make it a wired network this is my first router
YES YOU CAN IT SHOULD HAVE PLUG-INS FOR ETHERNET AND YOUR ISP INLET ON THE BACK OF IT ALSO G+MIMO OFFERS NICE SPEED WIRED OR WIRELESS.
Mar 09, 2009 | Belkin Wireless-G Plus MIMO Router with...
Bellkin G+ Mimo usb adapter - invisible
Use this tip as a check list.
Check if you set the correct SSID + Key and "connect if router is not broadcasting" set in your adapter configuration.
If you do not know Key you need to reset from Router.
If you missed SSID you can check on any PC when connected to WLAN and retrieve the name of NON BROADCASTED network
Jan 20, 2009 | Belkin Wireless-G Plus MIMO Router with...
Belkin G+ adapter connects to G+ MIMO Modem router,No Internet?
This sounds like your modem is storing the MAC address. There are 2 things you can try. 1 try unplugging the modem for about 5 mins and then plug it back in. If your modem has a battery backup you will need to also pull the battery out for those 5 mins.
Option 2 - Contact your internet provider and have them do a reset on the modem so that it will allow a new MAC address to be stored in the modem.
Dec 19, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Connecting to secure network
when enabling wireless security the router and adapter must be both be configured and configured in a fashion that both support. If you need help provide confirmation of your wireless router's manufacturer and model and the same information for any wireless adapters or computers with built-in wireless adapters to be wirelessly connected.
This will allow us to determine the common security options for all wireless devices you have.
Dec 16, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Open Questions:
Computers & Internet Logo
1,271 people viewed this question
Ekse
Alun Cox
