Question about Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher
Replacing drain hose
How do you get to release the drain hose to replace it?
  • 213 Answers
You have to pull dishwasher out all the way. if you have side panels open door and on left side youll see 3 screws, all torx head, remove screws to get side panel off. once you have the panel off youll see how to pull out drain hose
Posted on Nov 20, 2007
How to drain radiator on 2008 passat
You can always drain a radiator by removing the lower radiator hose; often the radiator has a drain **** you can unscrew as well. ON VW products there may be a quick-disconnect U-shaped wire bail that needs to be pulled out ¼-½" in order to release the plastic coupling (VW/Audi hoses are often unique, can't just buy one from the store) and then you have to winkle the coupling off. When you replace the coupling consider using a bit of raw coolant to lubricate the O-ring in the plastic coupling if there is one and/or replace the O-ring. If you break the coupling you'll need t? get a new hose assembly.
Feb 05, 2017 | 2008 Volkswagen Passat
How to replace drain hose defy 3 157 ddw
The hose is usually connected with a clamp at the lower (underside) section of the washer. You will need to pull out the washer from the space it sits, being careful not to damage the insulation packing around the tub area. Follow the hose to the connecting point and remove the clamp. Turn and twist the hose until it releases from the attachment on the washer. Clean the port well before replacing with a new hose. Slip the new hose onto the port and turn as you put it on the connector. Reset the clamp and feed the other end of the hose back to the drain under your sink. Your done. (In some cases, if an old hose won't come off, you may need to slice it off by cutting with a blade along the axis of the hose and splitting it open, then remove it)
Mar 18, 2014 | Dishwashers
Washer not draining
First is machine spinning? machine only drains in spin mode.
If machine not spinning check lid is closed and check lid switch and plastic plunger that operates the switch located on the lid.
If machine is spinning then most likely a blockage on the drain hoses or pump. if there is water in the machine, lower the rear drain hose to low level, if water starts to flow out the hoses are not blocked, more likely a pump failure. To replace pump first drain all water from the machine with drain hose at low level.
Tilt machine back and remove the belt from below.
Remove the front panel.
To gain access and remove front panel insert a knife or thin blade approx. 4" in the from each side in between the front seam on the front panel, this will release the lid clips, lift and hinge back the lid panel, remove the two screws securing the front panel and remove.
Pump on right hand side at the back, disconnect main hose from pump by squeezing hose clip with pliers (may be a bit of water remaining). Unbolt pump and pull forward with the drain hose attached until it can be disconnected and pump fully removed.
Check pump for blockage and damage to impellor, replace/refit in reverse order.
Nov 23, 2013 | Admiral AW22 Top Load Washer
First it wouldnt release the lock, then it wouldnt drain.
It most likely would not release the door lock because the water level was too high. Open the access door at the lower left on the front of the washer and drain the remaining water using the small hose there. Now, unscrew the big knob there and pull out the attached filter. Clean out filter and replace. If filter was not obstructed, replace pump motor.
Mar 02, 2011 | LG WM1812C Front Load Washer
How do you replace the thermostat on a 2007 Buick Terraza?
Engine Coolant Thermostat and Housing Replacement, Tools Required: Hose Clamp Pliers.
Removal Procedure IMPORTANT:Use the hose clamp pliers to gently release tension on the hose clamp until the hose clamp lock feature engages allowing removal of the hose.
Fig. 1: View Of Radiator Inlet & Outlet Hoses
  • Drain the cooling system.
  • Using the hose clamp pliers, release the tension on the hose clamp at the thermostat housing and reposition the clamp.
  • Remove the radiator outlet hose from the thermostat housing.
Fig. 2: Identifying Thermostat Housing & Bolt/Stud
  • Remove the thermostat housing bolt/stud.
  • Remove the thermostat housing.
  • Position the thermostat housing.
  • Install the thermostat housing bolt/stud.
  • Tighten: Tighten the bolts to 25 N.m (18 lb ft).
  • Install the radiator outlet hose to the thermostat housing.
  • Using a small flat-bladed screwdriver, release the hose clamp retention lock at the thermostat housing.
  • Fill the cooling system.
Good Luck and Merry Christmas!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 17, 2010 | 2007 Buick Terraza CXL Wagon
How do I replace the drain hose
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following for how to release the console and remove the cabinet for access to the pump and hoses.
You should see how the hose connects from the pump to the back of the washer, thru the back of the cabinet and to the drain hose.
May 31, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Trying to replace the drain hose which goes from washer to wall but hose will not release from inside the back of washer. I removed the small bolt to plastic piece which goes around neck of drain hose, but...
The hose end should be attached to the outlet side of the pump. You need to be able to access the lower inside of the washer to get at the pump, which may be either from the front or back depending on the make and model of the washer. On front loader washers, look for floor level screws that release a lower front panel.
Nov 15, 2009 | Office Equipment & Supplies
Where is drain plug for 1998 dakota 4x4 i need to drain radiator &what is the turning thing on the lower drivers side of radiator 4
1998 dakota 4x4
You can remove the drain plug in the bottom on the radiator.
You can remove the lower radiator hose. Since the vehicle is 10 years old you may want to inspect the hoses for replacement anyway.
) Make sure the vehicle is cool.
) Slightly loosen the radiator cap to release any pressure.
) Re-tighten the radiator cap.
) Place a suitable container under the drain point.
) open the drain.
) Re-loosen the radiator cap again.
) Allow to drain.
* At this point the radiator can be fill with water and a radiator cleaning agent- run the engine - allow to warm up.
* Re-drain the radiator - .
) Refill the radiator with water/anti-freeze.
) Dispose of waste fluid according to the local regulations. Some city dumps will accept it. Some parts stores may accept it. Do not pour down the drain or dump on the ground.
Apr 19, 2009 | Dodge Dakota Cars & Trucks
Water not draining
The belt may have failed due to the pump seizing up.
Remove the belt and turn the pump with your hand. If the pump seems hard to turn (should turn freely) replace the pump.
Jun 25, 2008 | Maytag SAV4655A Top Load Washer
Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher Logo
256 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
