Question about LaCie Silverscreen 80GB USB 2.0 - Portable Multimedia (093053682095) Hard Drive
Ieee1394 cardbus Hi .... have jvc camcorder new ...putting it through ieee1394  .... no info disc with jvc and my aspire 5310  will not recognize the camera ??.... ieee1394 has loaded OK  .. whats with the power input do i have to power this up.... oh yes windows Vista ... terry.b
0 characters
1 Points
Acer Aspire z5761 recovery disk wanted
You can contact Acer tech suppot and get the discs. It's cheap.
Oct 11, 2015 | Acer Aspire Z5761 23" All-in-one Computer...
How do i connect my jvc camcorder to my lpg dvd combo
All JVC camcorders came with a 3.5 to AV cable to connect to a TV for playback. Use this cable and connect to the input of your recorder to record to DVD/VHS. IF you lost cable, you can purchase it here
Apr 27, 2014 | Hard Drives
I backed up info from computer to a DVD-R disc and now I want to place some of the at info back on computer but when I insert disc get message DISC IS WRITE PROTECTED--how do I fix?
If its just saying write protected, that means you cannot copy new information on to the disc, you should still be able to retrieve and copy information off of the disc. If you haven't tried already open up the disc from my computer, and you should be able to view the files and copy what you need.
Sep 02, 2013 | Hard Drives
Do I need a disc to install
This is a external hard drive and no need for you to install any software to a computer in order for it to work , this is a plug and play device you just need to wait for the computer to recognize it after you plug it to a USB port and once its recognize its ready to use.
Jun 11, 2010 | Western Digital WD Passport 250GB Portable...
Hitachi DVD HDD camcorder and a mac imovie compatible???
Hi, You need to activate a add hardware to your mac, or plug and play so it will recognize the Hitachi DVD HDD Camcorder. Also you might need a plugin application software in order to play movie or video. hope this info will help you to solve the problem. Contact us if this will not work for you.
Aug 16, 2009 | Hitachi DVD/HDD HYBRID 30GB 2.7 WS LCD...
Verbatim 4gb flash cant be recognised
1. Download this tool:
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jun 02, 2009 | Verbatim CORPORATION 94933 USB 2.1GB...
I have Panasonic SDR-H18 camcorder. I have a HP Pavilian dv9000 laptop. I was able to transfer files to my computer as couple of months ago but I can't transfer anything now. About three weeks ago my...
Hi again,
For some reason, the chat session disconnected. Musthave been a glitch, delay/lag or plain disconnect. Our apologies forany inconvenience.
I have to agree that most probably theinterface/driver/software foor your computer to recognize and accessthe video from the Panasonic SDR-H18 camcorder was lost and thereforenneded to be re-installed again.
Pls start here. Download, install and run.
Justa start, do postback how things turned up or should you need additionalinformation. Good luck and Thank you for using FixYa.
Dec 02, 2008 | Panasonic SDR-H18 USB Hard Drive
Windows Vista Don't recognize my usb hard discs
last guest your a f u c k i n g a s s h o l e..i have the same problem with vista nad no one has an answer...
Aug 10, 2008 | Hard Drives
Not Recognized?
The device driver is causing a conflict with the system. If you have got any specific cd with hardrive install the driver from the cd. Otherwise , i would suggest try changing he manufacturer of the hdd and get a new one. If you have recently bought it.
Otherwise try creating a new account in windows vista on your computer and then try plugging in the drive
Aug 01, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
I've found that Windows Movie Maker (built-in to Windows XP), Adobe Elements, Adobe Premier, Sony's Vegas Video and  Pinnacle all work well with my canon camera.
Jul 16, 2008 | Hard Drives
LaCie Silverscreen 80GB USB 2.0 - Portable Multimedia (093053682095) Hard Drive Logo
19 people viewed this question
Top LaCie Hard Drives Experts
Brian Sullivan
Brian Sullivan
Are you a LaCie Hard Drive Expert? Answer questions, earn points and help others
