you should be able to go into the TV menu & switch it off. However, if you have it turned on on your source, such as cable box or satelite box, or DVD, you will need to turn it off the also.
I suspect it depends on the TV. On my Viewsonic TV, I can select my CC font by choosing Menu > Option > Closed Caption. When the CC is set to On, go to Option and select Font Size.
On a Samsung TV, I use Menu > Setup > Caption. With the Caption set to on, then choose Digital Caption Option and Size.
Note if the captions are being provided by a set-top box, you may need to set the caption size on the box directly.
Please add a comment with your TV manufacturer and model; I'll try to find the specific directions for your TV.
Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
In the Setup Menu, choose the Caption option.
Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
Digital Caption Style: There are two Caption Styles. One is the
automatic function set as the broadcaster, while the other is the custom
style where you can adjust the font size, color, opacity, background
color etc., accordingly.
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option. 1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
5)If you're watching aDVdon your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
