SOURCE: check gauges light
Possible bad guage, bad wiring, or bad sending unit. Check each one independently of each other, start with wiring first, then sending unit.
SOURCE: 2002 sunfire Drl problem
check wiring in front of washer bottle and harness will lead to passanger side follow it open up harness ussually broken wires inside causing dim or no headlights.
SOURCE: 2001 sunfire fuel gauge issues
your problem is your fuel level sending unit. replace it and everything will be good....
SOURCE: 2005 pontiac sunfire
I have the same problem.. i installed a toggle switch for the fuse so at least I can reset it while driving.. its still a pain so Im thinking my next step will be to drill a hole through the plastic and put in a small metal post to stop the tach from going past 7
has anyone taken theirs into a shop?
