Question about Minolta Maxxum 7000 35mm SLR Camera
Minolta maxxum 7000 35 mm camera
I took out my carmera inserted new batties. I snaped one pic and the shutter won't open again. If I shut it off and wait it will open again. I'm not sure if the camera is broken or just a program I need to shut off.
Re: minolta maxxum 7000 35 mm camera
I had the same problem. After I replaced the lithium backup battery, everything works perfectly. It is a CR2016 watch battery and it is located behind the silover plate inside the battery compartment. Remove the 6 screws and replace the battery. Note the polarity when you remove the plate because the camera will not operate if if it is put in backwards.
Posted on Mar 10, 2008
0 characters
3 Points
Minolta Maxxum 400si 35mm Is this a good camera? My husband and I are thinking about buying one used for our daughter who wants to get into photography. We found what looks like a good deal but I don't...
The Miinolta 400 si SLR 35 mm is an excellent camera for a beginner as well as the seasoned photographer. It has a complete automatic mode for the point & shoot picture taker as well as manual modes if you want to favor shutter speed over aperature or aperature over shutter speed. I've had one for years and have gotten excellent results.
Dec 09, 2010 | Minolta Maxxum 400si 35mm SLR Camera
My Minolta Maxxum 700si is blinking HELP on the screen
That same problem popped up on mine about three months ago after I put new film in it. I was only able to get a few shots out of it before HELP appeared in the window. Then everything locked up. I was able to reset the HELP by taking out the battery momentarily, but the problem reappeared. Also, after that, my pictures were mostly blank.
I opened up the back and found that one of the four thin metal shutter "flaps" had popped out and was jammed out of place. I probably snagged it with my fingernail when I loaded the film. I was able to tuck it back in place and now the HELP problem is gone.
Haven't taken any pics yet, but I'm hopeful. BTW, it also fixed my built-in flash, which had stopped working, also.
Jun 10, 2010 | Minolta Maxxum 700si 35mm SLR Camera
I have a Maxxum 7000i 35mm camera and in the display there is the word Help flashing what does this mean This happend after i tried a differnt lens, the lens opened than closed The lens that i tried was a...
Konica lenses do not fit Minolta cameras. I think you messed something up.
Minolta MC and MD lenses worked on the older manual focus Minolta bodies. They will also work on the Phoenix and Seagull clones of the old Minolta bodies.
The Konica lens should only ever be mounted on a Konica camera.
Your 7000i is now a Minolta paperweight. You need to send your 7000i for repair or replace it.
You could also look on Ebay for another Maxxum body to use your lenses designed for the Minolta A mount. As a rule, camera lenses are not interchangeable. You can use any Maxxum lens on any Maxxum body as a rule, but Minolta changed their flash shoe after the original 7000 series. Flashes that work with your 7000i will work with any subsequent Maxxum.
Oct 25, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Only partial picture on frame
it could be a shutter problem. however if it is only when using a flash it would be sync. for flash photography most cameras have a shutter speed that they sync at normally 1/60
May 26, 2009 | Minolta Maxxum 5000 35mm SLR Camera
Is the Minolta Maxxum 7000 capable of using infrared film?
once the shutter is closed or the shutter open and the mirror is up no light strikes the film except the image. don't forget to use the red markings on the lens as infra-red focuses on a different plane than visible light.
Mar 27, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 5000
I had the same problem with a maxxum 7000. Traced it to a bit of corrosion in the battery pack. It let just enough power through to run the computer, but upon releasing the shutter, it shut off.
You might check that. corrosion can be cleaned with vinegar.
Oct 07, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Shutter blades out on Minolta Maxxum 7000
It is possible to fit them back since they are flexible. It does require a gentle touch, with a lot of patience. I use angled tweezers for this task.
Replacement parts are no longer available. Used cameras can be found on ebay and the like.
Feb 13, 2008 | Minolta Maxxum 7000 35mm SLR Camera
All pictures have black at top of picture
the shutter assembly is not fully open when shooting. Maybe the motor driving is possibly weak already. You have to bring it to the service center, if the price is not right, better buy a digital camera compatible with your minolta lenses. ( films are getting obsolete fast, but the lenses are not)
Aug 26, 2007 | Minolta Maxxum 7 / Dynax 7 35mm SLR Camera
Minolta Maxxum 7000 35mm SLR Camera not working
Dear Minolta friends,
I have recently bought a second hand Maxxum 7000 and a AF lens, but found the body not ocntrolling the aperture while shooting. I know 7000 has someting special. Is my problem is due to lens and body compatibility or actually the malfunction of the body. I am sure the AF lens is ok since i have tried it working with another minolta af body.
Can give me an advice?
Aug 02, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 400si "help" on screen
It is a common problem on these cameras. The gear assembly inside the camera body has failed and needs replacement. $$$
Jul 12, 2007 | Minolta Maxxum 400si 35mm SLR Camera
Minolta Maxxum 7000 35mm SLR Camera Logo
172 people viewed this question
Top Minolta 35mm SLR Cameras Experts
Mark Schmit
Mark Schmit
Are you a Minolta 35mm SLR Camera Expert? Answer questions, earn points and help others
