Question about Compaq Diskette Drive / Cd-Rom Cable Deskpro 4100 5100 Minitowers Presario 900 9200 9500 9600 Prolin...
Help ive lost my windows xp key code and there is no way i can get any tech support im over seas and stationed in iraq please help were can a get a new key code??
  • 22 Answers
Re: help
If your machine should have the XP key on a tag on it. If you no longer have the tag, the restore CD that came with the machine often (but not always) will re-install without a key. On the other hand, if you have a working installation and need to recover your current key, you can get a FREE utility to do that from:
Posted on Nov 14, 2007
0 characters
3 Points
Cd rom on windows XP wont work?
how old is the computer cd rom might be time for new one
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it if this fails you might try cleaning the lens it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
Jun 12, 2012 | CD Drives
I have 1 note book LG X120 with windows 7. when im trying to install Windows XP proffessional through a USB CD ROM its showing the following Message * To specify additional SCSI adapters, CD-ROM...
Hi lionking2022!
Since this is a USB CD_ROM, you need change some settings in the bios for it to be detected and the system will actually boot from it.
1. You enter your BIOS
2. Look for the tab that will contain IDE settings
3. Change it to AHCI
4. Save and Exit
You may know try to boot from cd-rom and install your windows xp.
After the setup or installation is finished don't forget to changed it back to SATA or whatever the setting was.
Hope this will help.
Thank you for using Fixya,
Mar 24, 2011 | AGPtek USB External CDROM Drive For LG...
Please can you help me. I used to have a windows 98 computer, but then upgraded to windows vista home premium. But when i tried to put my Creatures 2 game on it, it comes up with an error message. There is...
you might need to update to a better version of directx
also upgrade to xp its not as much of an upgrade and is the most solid/stable operating system
hope this helps
Jan 20, 2011 | CD Drives
Cannot find product key for windows xp
Down load and install Winkey finder :-
Once accessed it will show you your windows product code.
May 08, 2010 | E-Machines emachines (emachinees) CD-ROM...
XP SP2 Fujitsu Siemens Ref FSP : RCDWXPHFRN010 / 10600573874 CRC : 758D6AB8 Key accès !!! Regards
The key is a Microsoft Windows key.
The key cannot be provided here, as this will be a law infringement.
Microsoft keys are not bound to the installation CD, but to the licence stickers placed on top of the computer cabinet, or on the laptop.
Check if you have a licence sticker on your computer.
Usually generic windows keys for same version also work on customized install disk like this. If the system is for example XP Home Service Pack 2, and you have purchased a generic version of the same system, then you can use the key on your FS CD setup.
Generally there is no way to retrieve legally a lost Windows key. You can try calling Fujitsu Siemens, but I am afraid they will tell you the same.
From here you can get Fujitsu Siemens contact in your area: Product support, software evaluation, drivers, patches and other
Jan 30, 2010 | Fujitsu CD Drives
My laptop wont load to Windows XP when it tries to I get the following message. STOP:c0000221 {Bad Image Checksum} The image shell32.dll is possibly corrucpt. The header checksum does not match the...
your windows is surely corrupted.. install your windows again... if you dont know how to install your (
please vote for sure this will solve your problem...
Sep 26, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
Every cd is showing as a ''AUDIO CD''
your cd-rom is infected by viruses... install new windows...
Sep 21, 2009 | CD Drives
Had to reistall microsoft office home and student 2007 and lost the product key.
i know the website from wich u can get product key...
BUT PLEASE VOTE FOR sure u get key here..
Jul 17, 2009 | CD Drives
I have compaq presario C700-C765TU ihave lost all my drivers i want all drivers how can i inctall
This system was made to host Microsoft Windows Vista, HP does not distribute XP drivers.
If you need Vista drivers, then download from HP Here: Compaq Presario C700 Notebook PC series - Download drivers
If you need XP drivers, then read the websites below:
Help in Finding XP drivers for Compaq Presario C713NR or C700
Sound Driver for a Compaq Presario C700 Windows XP
windows xp drivers for Compaq c700
Mar 02, 2009 | CD Drives
CD Drives Logo
48 people viewed this question
Top Compaq CD Drives Experts
Brian Sullivan
Brian Sullivan
Ricky Ostrom
Ricky Ostrom
Josh Whitehead
Josh Whitehead
Are you a Compaq CD Drive Expert? Answer questions, earn points and help others
