Question about Cub Cadet Garden
I have a2011 cub cadet zero turn mower but when I push the left side handle it doesn't barely move . Like theres hardly any power to move the left side. What is a matter with it? Is going to cost alot
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
May be low on hydraulic Oil.
Theres also a nut that releases the hydro pressure make sure it is not loose. Make sure there are no leaks. And make sure on the back of the mover that the hydro release is not pulled. If there are no issues then there is a issue with the hydro pump and yes the repair is costly. A replacement pump is roughly $250-300 dollars.
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_722ea729aae6fd07
Posted on Aug 17, 2016
SOURCE:
  • 62 Answers
SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Posted on Apr 18, 2009
  • 146 Answers
SOURCE: I have a Cub Cadet RZT 50 mower. The left drive
First, check the level of the hydraulic fluid (usually the dipstick is right inside the fill cap, and you just raise the seat to access it). If it's low, fill 'er up with the right fluid.
If that's OK, test if the lack of 'pull' affects the left wheel in both forward and reverse -- try going up a hill forward, and backing up it in reverse. If it affects both directions, maybe you will be lucky -- the problem could be that the bypass for the left hydraulic motor has opened somehow. (The bypass is used to let you push the mower by hand in case of an engine failure, etc.) So look for a fat-headed bolt sticking out of the left hydraulic motor. Check that it's tight -- rotate it just like you would tighten a bolt, clockwise. If it wasn't tight, that may be the problem; just tighten it and try the mower.
If this doesn't resolve it, you probably have a problem in the hydraulic valves, hoses, or motor, and a trip to the dealer is needed. Probably won't be cheap, sorry my friend. Good luck, and please rate if this was helpful, thanks!
Posted on Jun 04, 2010
  • 41 Answers
SOURCE: Is there an adjustment to (toro zero turn)
yes,on the bottem of the handles
Posted on Sep 08, 2011
  • 6468 Answers
SOURCE: My cub cadet zero turn mower wont turn right or left. It will go straight or reverse but wont turn. I just changed the drive belt, but that's all I've done to it.
take a good look at the linkage
Posted on Apr 08, 2012
  • 21 Answers
SOURCE: i need the drive belt diagram of the cub cadet
3 yrs later.
To find belt diagram, Look for a diagram sticker underneath the driver side foot rest. (faces the ground). Goodluck people.
Posted on Jun 13, 2013
Why do I have to push so ******* the handle to make it go forward?
If this is a self powered mower, you probably need to make an adjustment. (All self-powered mowers need an occasional adjustment). Check your owners manual for the procedure on your mower, they vary by brand and model).
May 16, 2016 | Cub Cadet I1042 42" 18HP Zero Turn Tractor...
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
Will not move
The transmission is shot. A common problem. Mine died after 3 years and 200 hours of use. Estimate to fix was almost $2000. I scapped it and bought a better mower. There was a rtransmission design defect in the RZT series.
Jun 01, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Whenever i move my left lap bar up on my cub cadet zero turn my mower shuts off
Under the seat...there is an operator presence safety switch...it is faulty and must be replaced
Apr 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
118 people viewed this question
Top Cub Cadet Garden Experts
dannydoesita
roeb
Marvin
Marvin
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
