Pentair Mastertemp 250 pool heater
Absolutely not, they are not interchangeable!
Each set of wires, go to a specific sensor or switch.
The opposite end of that wire goes to an electronic circuit board with specific logic. It is in constant communication and or waiting for communication/confirmation, from that specific switch or sensor, so that a specific action can be taken for a specific situation, all based on that specific sensor or switch that it is connected to. So therefore do not rearrange the wires.
purple wires usually go onto a pressure switch.
Red wires will normally go on to the automatic gas shut off switch, or AFS.
there are usually two sets of two wires for the high limits, and they are colored orange. Because there are two high limits.
Brown wire, I'm not sure of? I don't remember any brown wires on a master temp. Is it possible that the brown wire that you see, has discolored and it was an orange wire, or a set of orange wires previously?
Testimonial: "Thanks for responding Mike actually I didn't pose the question properly here. But you answered it anyway on my other post. It wasn't whether or not you can hook the Thermistor wires to the AGS etc which of course you cannot but whether or not it matters if you switch the right and left of each pair which it seems does not matter as long as they are going to the correct sensor."
SOURCE: I have a Pentair Mastertemp 250 pool heater with
This is an ignition flame falure code. Could be you don't have gas getting to the pilot, no spark to ignite the pilot or your ignition is not reading the flame. Sorry to say but it's probally time to get the pool guy out to look at it. Good luck.
SOURCE: I have a mastertemp pentair
Since I don't know exactly what model you have I can only suggest you call the Pentair technical support at 800-693-0971 andthey should be able to help you figure this issue out.
I hope this helps.
