1992 Buick Century Logo
Posted on Jul 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Knocking noise coming from belt area. when belt
Knocking noise coming from belt area. when belt removed and engine started knocking noise goes away. pulleys are all good, fluids ok, knocking noise increases when wheels are turned
Anonymous
Level 2:
  • Expert 77 Answers
  • Posted on Nov 22, 2009
Anonymous
Expert
Level 2:
Answers
77
Questions
8
Helped
29030
Points
129
Had the same issue and it turned out to be the balancer. Not too difficult to fix any questions or advice, I am happy to help you. Justlet me know. Good luck
Justmercy
Level 1:
New Friend:
  • Contributor 43 Answers
  • Posted on Nov 01, 2009
Justmercy
Contributor
Level 1:
New Friend:
Answers
43
Questions
6
Helped
16740
Points
99
It is very common for the harmonic balancer on these to fail and it sounds like an engine knock. It almost stops when you remove the belt. With belt removed, try to turn harmonic balancer, if it turn back and forth, it is bad. You need to replace it.
Anonymous
Level 2:
Sergeant:
  • Expert 400 Answers
  • Posted on Jul 11, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
400
Questions
0
Helped
163984
Points
951
Belt maybe the wrong length,and or maybe too tight causing undue stress on one or more pulleys. check bearings on the pulleys
2helpful
Loud knocking coming from lower timing cover area 1995 toyota camry 2.2
I do think that loose key and keyway could cause the knock. It would also explain the loss of power, due to the engine timing not being spot on.
A knocking big end or main bearing would not improve at higher revs, it would get worse.
Act soon before the keyway in the crankshaft itself is too badly damaged, by removing the crankshaft pulley, lower timing belt cover, and belt guide. You can then get a precise idea of what exactly is worn. This may assist
http://www.turboninjas.com/camry/eg1.pdf
You may actually have to find an oversize key, for a neat fit in the crankshaft. It may be necessary to file or grind it to fit. Engineering supply houses stock them, eg
http://engtooling.com/webshop2/
Engine makes knocking noise at low rpms and quiets as rpms are raised. what is the problem
IS IT SUPER CHARGED ?
TRY REMOVING DRIVE BELT(S) AND ONLY BRIEFLY RUN TO SEE IF NOISE
GOES AWAY 2 BELTS ON S/C ENGINE AND ONLY 1 ON REGULAR ENGINE
I have an upper knock on the front of the engine. What could it be?
While the engine is cold, remove the serpentine belt and start the engine and see if the knock goes away. If the knock goes away, then you might have a bad belt pulley. Good luck, Gary
Engine is knocking sounds like from the belt area
You need to remove the belt and check each pulley for looseness and noise when turning by hand. You can also start the engine without the belt on to see if the noise is coming from the engine itself.
1helpful
2answers
JUST CHANGED WATER PUMP, POWER STEERING PUMP, BELT TENSION ASSEMBLY. EVERYTHING OK FOR ABOUT 2 WEEKS AND NOW THERE IS A KNOCK OR RATTLE COMING FROM THE FRONT OF ENGINE. WHEN BELT IS REMOVED THE NOISE GOES...
the damper could be bad if it's the type with the rubber inbetween the pully and the the rest of the damper. check that and see if it is separated. if not looks like your crankshaft bearings could be bad
When engine is started there a noise that come around the belt area, after a mintue are two , it fade away
Need more info, what kind of noise. How many miles are on your car.What engine is in your car. If the noise sounds like an engine knock, have someone take the tension off of the belt while you check to see if Harmonic balancer moves back and forth. If it does it needs to be replaced. It will sound like an engine knock when bad. When this 1st starts to go bad it is only there part of the time. If it is this, it will eventually be there all the time and get much worse.
I own a 2001 galant es 4cyl. automatic and started my car up 2 days ago and noticed a loud knocking noise coming from the engine. I opened the hood and the noise was coming from the area where the timing...
yoy could have a bad t belt tensioner or bad t belt pulley. get this looked into right away. you have what is known as an inteference engine. if you lose that belt for any reason, it WILL drop a valve, and your're looking at a lot of money for an job.
Knocking or pinging noise at idle
check your timing chain or belt might be loose and or your belt tensioner is not working
4helpful
Knocking noise coming from air intake section on top of engine
The top section of the engine is called a '**** shell' there are baffles inside tha break away and knock. If you press down on this plastic section and the knock goes away. then you have to replace it. It unbolts usinh\g 10mm socket. You need a short one and a long one. also remove the IAC solenoid above the throttle body. **** shell is a dealer item only. also replace the gasket seal.
If the **** shell does'nt come, out gently use a pry bar between the throttle body and the cowl area, for more clearance.
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
