Question about Dell Dimension 3000 PC Desktop
Cannot boot my dell dimension 3000
I have a similar prob my com wont boot it says the following :
primary drive 1 not found
secondary drive 0 not found
secondary drive 1 not found
strike the f1 key to continue, f2 to run the setup utility.
if i stike f1 key the com says windows starting etc. only thing that happens is the dell desktop picture appears, no desktop icons or start menu. It also wont allow me to open the cd drive at any time, so i cant re-install with the windows xp cd. any ideas any help would be greatly appreciated thanks
  • 3 Answers
Look at this link read carefull and try again http://www.goodells.net/dellrestore/fixes.htm
Posted on Dec 23, 2007
    Genius:
  • 1,601 Answers
Did you check inside and see if all the cables are attached?
Is the hard drive spinning, it may be bad.
Did this just happen?
Posted on Nov 14, 2007
How do I run a set up program
Generally, one enters the BIOS Setup screen by pressing either F2 or Del. There is usually a message on the bottom of the first boot screen that indicates what button is correct for that model.
Looking further into the details that you have given, it seems that your CMOS battery has died, so you will need to replace that. (This is what is causing the "Time of Day Not Set" message most likely.) You can get the appropriate battery at Radio Shack (if nowhere else) for about $5 or $6.
Oct 17, 2014 | Dell Dimension 3000 PC Desktop
In the boot device menu, drive 1: no ide device what does this mean?
test for secure dust free connections or replace the 40 pin ide lead from mother board to hard drive
include electrical extensions
operating system cant find ide hard drive
hope it helps
Nov 12, 2011 | Dell Dimension 3000 PC Desktop
My computer cannot find he primary hard drive
Hi friend,
this is not your system problem. it is your wire problem. You need to change your hard drive cable then try.
Dec 17, 2009 | Dell Dimension 3000 PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Quantum Fireball lct 30gig not recognized in Dell Dimension 3000
Turns out this particular drive needs TWO jumpers on it, to set it to CS. I received it used with a single jumper in the Master position, but after checking the Maxtor/Quantum website, it listed the jumper positions and showed the second jumper. As soon as I installed the TWO jumpers in the correct position, the Dimension 3000 booted right up and let me reinstall Windows. I had scoured the internet for many hours looking for a solution, none solved it until I decided to check the manufacturers website. Always start there!- Solved!
May 18, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
No boot device available
Make sure all the connections to the Hard Drive are tight and secure. Then see if it will boot. If not then try loading a windows cd and see if it detects the Hard drive. If it does not the hard drive is no good if it does try running the automated system recovery you may have a corrupt MBR file.
Dec 22, 2008 | Dell Dimension 4400 PC Desktop
Dell Dimension 3000 reformat trouble
please re partition the hard disk and install the operating system. if the same error continues then change the ram and try
Jan 28, 2008 | Dell Dimension 3000 PC Desktop
Won't boot
Just reformat, see if that helps.
Oct 18, 2007 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
443 people viewed this question
Alun Cox
