Question about Panasonic PV-V4022 VHS VCR
How to repair a panasonic pv-4022
Crinkles/damages the bottom 1/16 inch of tape. First started w/Maxell 8 hr tapes, but now damages even the 6 hr tapes.
    Problem Solver:
  • 5 Answers
Possibly the idler, BUT also it can be the tape guides. sometimes, you have to unscrew a little bit, and it's a-1
Posted on Nov 16, 2007
Water damage to ceiling
Cut off the loose make flat tape and drywall mud
Mar 06, 2014 | Drywall
Why did my panasonic PV-9450 eat a a tape?
Hi Melanie -
First, you should keep away from the T-160 tapes as they are thinner and more likely to jam. The T-120 or less sizes are better. Next, use high quality name brand tape - not the off-brands found in the bargain bin.
Do the regular maintenance. All tape is "dirty" (including cassette, 8 track, reel to reel, etc.) and will deposit dirt on the tape heads and "transport" mechanism. Transport consists of capstan and pinch rollers that push / pull the tape in and out of the housing. when dirty, they slip and interfere with the "pick up" of a quality picture from the tape. Use of a quality wet cleaning system at regular intervals (or whenever picture quality deteriorates or tapes jam) is highly recommended. Here are some googled results for wet VHS cleaning systems:
http://www.google.com/search?q=wet+vhs+tape+cleaner&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a&channel=sb#channel=sb&q=wet+vhs+tape+cleaner&rls=org.mozilla:en-US:official&safe=off&tbm=shop
Mar 03, 2014 | Panasonic PV-9450 VHS VCR
My camcorder is spoilt and I am left with many mini DV tapes which I cannot download to the PC without the camcorder. Is there any solution for this?
since it is in digital format a standered VCR wont read them the hi-8 tapes have a bigger VCR tape you can put the hi-8 tape in and insert that into a VCR but the hi-8 is an analog tape and.mini-DV is digital "DV = Digital Video" so a standard VCR wont read them the only way is to borrow a friends Mini-DV camera and copy all your tapes over. they do make a Mini-DV player but even the cheap ones cost more than a new camcorder would! Sorry to hear about your camcorder I hope this helps
Aug 12, 2010 | Panasonic PV-GS400 Mini DV Digital...
My Panasonic pv-gs180 doesn't record.
If you have Head Cleaning Cassette play it at 10 seconds or use new Cassette for 10 minutes play or record. Otherwise Video Head damage
Mar 10, 2010 | Panasonic PV-GS180 Mini DV Digital...
The cassette is stuck...
the tape is trapped in the mechanisms, you have to strip the VCR down to get the tape out
regards
Nov 26, 2008 | Panasonic PV-7400 VHS VCR
Mini cassette tape is wrapped around one spool inside the casette
1). Remove the five screws from top half of cassette shell. If the cassette shell halves are glued together, very carefully split the shell with a Phillips-head screwdriver. Maneuver the screwdriver around the shell to break its seal. Avoid getting cut or damaging internal components of cassette.
2).Carefully lift off the top half of the cassette shell.
3). Pull the head if the tape from the left reel.
4). cut-off the damaged edge, and attached a peice of sctoth tape to the shining side of the tape, and leave about 1/2 inches of scotch tape beyond the head of the recording tape.
5). trim the sctoch tape using single edge of the sctoch tape razor or X-Acto knife to the same width as the recording tape.
6). carefully insert and tape the head of the recording tape to the right reel. and manually wind the tape till the recoding tape is flat to the front of the recoding pad.
7). carefully close the top shell, make sure not to pinch the tape. use your finguer trun the right reel, make sure the tape winds freely.
8). secured the top with screws.
Nov 24, 2008 | Maxell 179030 Microcassette 3-Pack (60...
Panasonic Palmcorder PV-43 turns off with a tape inside
you definetly have a tape mech fault and this is going to have to go for repairs to panasonic.
Apr 25, 2008 | Panasonic Palmcorder PV-GS12 Mini DV...
PV GS 35 wont play tapes from other cameras
perhaps it has to do with the SP and LP settings, I know certain video editing programs won't capture video recored in LP.
Aug 18, 2007 | Panasonic PV-GS35 Mini DV Digital...
Panasonic PV-DV103D
This is actually a problem with the ribbon cable. When the tape is put in and the tape door is pushed shut it jars the internal ribbon cable. Years ago I found this tip online & it fixed it!
Quote
"Ok, here goes, I had the exact same problem on my pos Panasonic pv-dv203d. After many times of taking it apart and many frustrating calls to Panasonic, I've finally figured it out, I hope it helps on your cameras.
Remove the bottom plate from the Camera (four screws, plus one near the LCD screen).
Pop off the bottom plate of the camera
Look at the ribbon cables carefully, and make sure they are all snug in the plugs. The tape transport mechanism may move them out of place."
Every now and then our will start to act up & hubby unscrews the bottom of the camcorder (Panasonic PV-DV203D), gently maks sure the ribbon cables are in place, replaces the bottom plate & it's worked for us every time. i hope this helps!
Mar 12, 2007 | Panasonic PV-DV103 Mini DV Digital...
Panasonic PV-DV702 Garbled playback - any solutions??
Try a different tape. The tape itself may be bad.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Panasonic PV-V4022 VHS VCR Logo
102 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
