Question about Ricoh CL4000DN Laser Printer
Down the left side of page has a lot of noise or lines and as it progresses to the right side it tends to deminish some.
  1. Noise in picture - Whats causing this? We have replaced all the consumables.
  • 1 more comment
  • Anonymous Nov 14, 2007
    I have had this same problem on one CL4000DN where I have replaced the transfer belt, the toner & drums or imagers and regardless of what color is printing the distorted image you see in the picture shown will show in the same color. It doesn't show in another CL4000DN using the same supplies as this one. I'm assuming it could be a power supply issue with a charge problem possibly. Do you have any feed back on this issue?
    Thanks
  • Anonymous Jan 26, 2008
    I have the same problem ... have you been able to find a solution?
  • kerrieboys Nov 12, 2008
    I am having the same problem. Left side full color streaks top to bottom of page. Help? We replaced toners.
First remove the blade and also waist toner and fix the drum then pour bit face powder or toner powder on to the drum and rotate to both the sides later it will get ok... or to contact www.inkworld.in / mailroom@inkworld.in
Posted on Oct 06, 2011
  • Ricoh Master
  • 1,113 Answers
I dont think it is noise more like a blade not cleaning.
You say you have replaced everything, I would think the was from Ricoh 402322 - Laser Printer Transfer Unit or
one or two of the drums (black and cyan) have these been replaced or have you just replaced toners.
Posted on Nov 14, 2007
1998 Dodge Stratus rubbing noise when turning. Sounds like rubber against metal. No popping noise.
It could be several things ....
Wheel bearings - jack the front driver side up. First ... just rotate the wheel ... you should hear NOTHING. Any noise menas there is probably a wheel bearing/hub issue. Now take hold of the tire in the 9am and 3pm positions. Try to push/pull from side to side ... if there is any "play" in the wheel the bearings are going.
Brake line interference - a lot of brake lines have a plastic sheath in the wheel well area ... check to see that the line/plastic sheath shows no wear when you have the wheel off...that might cause the issue.
Steering linkage - even though the upper control arms were recently replaced look at all the ball joints and grab hold of them and see if there is any play/movement.
Repeat on the passenger side..
Good luck on your troubleshooting
Jan 24, 2018 | Dodge Cars & Trucks
I have a 2000 ford expedition 4x4 the front right side makes a clicking noise while driving. Any ideas
Clicking Noise From Left Front Tire Area - F150online Forums
www.f150online.com/.../47713-clicking-noise-left-front-tire-area.html
Aug 11, 2001 - I have a clicking type noise comming from the left front tire. It does not ... I can really hear it when I'm driving beside a sound wall or the side of a building. ... the sound. (Yeah right!) ... Almost forgot: 1999 Ford F150 XLT Supercab 5.4 4X4. ... My 2000 4X4 had a ting ting noise coming from the left front wheel. Intermitent Grinding Noise on 2004 F150 4x4 - Page 5
Jan 15, 2010
Popping noise in front end.
Oct 26, 2009
Clicking noise at low speeds.
Aug 7, 2009
Annoying clicking sound in rear of truck?!?!
Jun 8, 2009
More results from www.f150online.com
Jan 05, 2016 | Ford Cars & Trucks
When driving my ford focus 2011 zetec 1.8 is it normal to hear a lot of road noise even though the windows are shut. this seems worse when driving over 40 mph
Not really. Tires will cause noise. Th noise will change over different types of pavement. Bearing noise won't. Except when you are turning left or right. Turning left and the noise gets loader/worse is the right side bearing. Vise versa for the left.
Feb 22, 2015 | Ford Cars & Trucks
2009 impala. Noise in right front when turning right just briefly. The skid an abs lights flash but go back off.
You need to check your brakes right away, it could save you a crash and a lot of money.
Feb 03, 2015 | 2009 Chevrolet Impala
I couldnot copy anymore and heard a lot of noise and error 5C00. I moved the cartridge cradle to the left and cleaned a 1cm square pad and the surrounding from ink and now I get the same noise and cod
5C00 means that a Generic Service error has occurred in your printer.
Chech that the Timing Strip is in the right position and the carriage guide/Cord that moves the carriage left and right isn't gone out of the motor wheel or at the left side on the plastic wheel
If this happened try to replace the guide on the wheel - motor
If the timing strip (a little strip with a lot of little vertical lines on it is dirty, clean it with water. DO NOT USE Alcohol or other solvents, if just one of the vertical lines are damaged you have to change the strip.
Hope the best, ADCSFXworks Printing Center
Nov 21, 2014 | Canon PIXMA MP620 All-In-One InkJet...
What could be causing a vibrating noise when going slow speeds but decreases when in faster speeds
Hi Chris, I'm glad to help! Vibrating / Roaring sounds can be anything from rear or front diff problems. Drive Line U-Joint problem. Wheel bearing bad. Even transmission problem. You have to pin-point where the vibration is, is it in the front, in the rear, on the right or on the left. Is it in the center of the vehicle and so on. Hope this helps and have an awesome day Chris!
Jan 04, 2014 | 2007 Jeep Liberty
It starts In 3rd and when in 5th while still accelerating, a noise which sounds like it's coming from drivers front side, the best I can describe it is it sound like a commercial paint shaker shaking a...
Noises from axles can be really deceiving. The sound is transfered throuh the transaxle and can resonate through the entire vehicle. The turning to the left thing makes it sound like a problem in the right wheel/axle area. Wheel bearings and axles tend to make worse noise when they are on the OUTSIDE of the turn. More of the vehicle weight is shifted to the outside due to centrifugal force. Thus, if the noise is louder when turning left, this puts the right axle to the outside of the turn and the most likely to be the source of the noise. (and vise-versa) The fact that the noise calms down while cruising makes me believe that it is not a wheel bearing. Wheel bearings can make more noise in turns, however, they usually make a "roaring" or loud "humming" noise that gets louder with speed. An axle is more likely to change or get louder according to engine load more than rotational speed. (Way worse while accelerating or climbing a hill) I would be taking a hard look at the right axle.
Jan 25, 2011 | 1997 Geo Metro
Recently noticed when driving over 40mph, I hear a loud humming like tire tread noise, coming from the front. When I'm turning right it gets worse. Turn left and it virtually vanishes. Is this the...
yes.this means the left wheel bearing is bad, because when you turn right the pressure is pushing down on the left wheel causing noise and when you turn left the pressure then pushes down on the right side removing pressure from the left side causing noise to stop.. this is why when you turn one way or the other the noise stops and starts.
Jan 16, 2010 | Chevrolet TrailBlazer Cars & Trucks
Fan started making noise
I have one of these, and every so often, the fan would start making a loud clicking noise. I discovered that if I shut the fridge off for a while and left the door open to defrost it, it'd work fine again for a while before the noise came back. Apparently, some ice was building up between the metal heat-sink and the fan, causing the fan blades to scrape against the ice/frost build-up and make the "tick, tick tick" noise.
There is no compressor in the Avanti EC15W-2 mini fridge. It uses a simple Peltier junction device to transfer heat from the inside of the fridge to the outside/rear of the unit. So it should never get very loud at all, unless one of the two fans in it is acting up in some way.
Aug 15, 2009 | Avanti EC15W-2 Compact Refrigerator
Ricoh CL4000DN Laser Printer Logo
111 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
