Question about JVC GR-D370 Mini DV Digital Camcorder
How to transfer JVC GR-D370U videos to Windows 8 PC.
I have the DV cable, but the computer won't recognize the camcorder.
SOURCE:
  • 473 Answers
SOURCE: JVC GR-DVF31 - How to transfer MiniDV to PC?
buy that wire, check ur camcorder if it has 6pin or 4pin for firewire then check ur pc if it has firewire card...if not you have to purchase the ieee1394card. install it then connect your camcorder to pc through firewire and that will be it.. u also need to have a software for video capturing and editing like adobe, roxio, pinnacle , etc...hope that helps.
Posted on Sep 05, 2005
TTM77
  • 19 Answers
SOURCE: How to transfer the video in Mini DV to my computer
I suggest getting the PCI IEEE 1394 also known as FireWire card. Most of the time these Firewire card comes with a Video editing software but verify because you will need some form of video editing s/w to record the video. After recording then you can edit it however you like and transfer to DVD/etc. Always a pain in the as to edit video. I've done it a couple of times. So have fun. I still have not manage to find a Video editing s/w that will do a 5.1 audio or multiple audio tracks (similar to switching between languages)
Posted on Sep 06, 2006
SOURCE: Computer won't recognize Gr-DLV 300 with firewire connection
My Sony camcorder wouldn't work with firewire either until I downloaded a fix at: http://www.microsoft.com/downloads/details.aspx?FamilyID=CA0F2007-18B5-4112-8BD6-8BF4BD3130B9&displaylang=en
Hope that helps!
Posted on Feb 01, 2008
Bubbabear64
  • 2794 Answers
SOURCE: JVC GR-DVP7 - Video to PC / Firewire Cable ... where can I get one?
Best Buy has a 6 pin to 4 pin firewire cable. You will need some software as well to copy to the hard drive such as Pinnacle Studio if you don't have on already.
Once the cable is plugged in and turned on Studio will detect the camera and run the program.
Posted on Jul 04, 2008
SOURCE: Need to Import videos from the JVC GR-D270U to my PC
I disagree VERY much with Bubbabear64. I tried what he said and I had lots of problems. The computer wouldn't import and sometimes it wouldn't recognize the camera. I installed the 2 programs that came with the camera on the CD, and all of a sudden it worked great. So install the audio driver and the picture importer on the JVC disk that came with your camera.
Posted on Dec 08, 2008
Hi, I have a JVC GR-D750AA digital video camera. I do not know how to download the things recorded to my PC. I have also bought the USB cable n tried but the camera USB port is not recogned by the PC. I do...
Turn the power switch on your camcorder to "Off." Connect the USB cable that came with the camcorder to the USB port on the camcorder. If you are using the DV cable, connect one end of the cable to the computer first. Put the other end of the USB cable into the USB port on your computer. If you are using the DV cable, connect it to the camcorder. Power on your camcorder. Wait while your computer recognizes the attached JVC GR-D270U camcorder. Typically you will get a pop-up on your screen asking how you want to proceed once the camcorder has been recognized. Open your video editing software, such as Adobe Premiere, Roxie, iMovie or Windows Movie Maker. Import, or capture, the video from the camcorder to your computer using the video editing software. For example, in iMovie you click on "File," then "Import from Camera" to download the movie from your camcorder to the computer.
Jan 13, 2018 | JVC GR-D275 Mini DV Digital Camcorder
Video camera to pc operation
Probably you need to install camera software first.
Do you have the install disk?
Oct 08, 2008 | JVC GR D370US camcorder Mini DV
Having difficulty connecting the jvc gr-d370 to my computer using Windows Media. What must I do to retrieve the video from the camcorder using the USB cable?
I had this same issue. I solved it. The USB cable will NOT work to transfer video. You need a IEEE-1395 fire wire cable. I purchased the internal card and cable for under $20.00 for my DELL computer direct from dell. After you connect your camcorder to your computer, I clicked on windows photo gallery. Then in top left corner, click file and "import from camera or scanner. Your camcorder must be on video mode and play mode. Your computer should recognize the camcorder, click on it and then it will give you options, like you can upload and record direct onto DVD. I liked the option of uploading manually because if there are blank sections on the DV tape, the computer will stop uloading. Hope this helps.
Dec 28, 2010 | JVC GR-D370 Mini DV Digital Camcorder
GR-D370 Mini DV Digital Camcorder: i have a jvc dr-d370u and i can't format my memory...
This model can accept SD card for up to 2GB only. You may be have more than 2GB card, otherwise there is an internal problem with your camera that needs repair. Hope this helps
May 17, 2010 | JVC GR-D370 Mini DV Digital Camcorder
We bought our gr d370u camcorder at pawn shop but my computer only sees the memory card not the video do i need driver for this or dv cable?
Dv cable is available in the market, not that difficult to find this thing, buy a good quality cable, sometimes this causes trouble in connecting. Good Luck
Feb 22, 2010 | JVC GR-D370 Mini DV Digital Camcorder
Looking for sofeware for the jvc gr-D370u lost
Please go to the following link to download the drivers and manual for your JVC GR-D370.
http://camcorder.jvc.com/index.jsp
After you install the drivers you would be able to download and view them on your PC.
If you would like to touch the pictures or make major changes you should consider buying additional software.Good Luck!!!!!!
Jun 09, 2009 | JVC GR-D370 Mini DV Digital Camcorder
How to connect JVC GR-D820E camcorder to PC
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC GR-D370 Mini DV Digital Camcorder
JVC GR-D870 digital camera, how to transfer Min Div tape to PC
Hi, You need to use 4 pin firewire cable to connect to the PC. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC Cybercam GR-D200US Mini DV Digital...
Record directly from jvc model GR-- D370U Digital Video Camera to my pc
Sorry, but it's not possible to record directly to a PC. Windows movie maker will only record from a tape. Please use a quality cable like Belkin, I have had issues with the cheaper firewire cords.
Good luck
Oct 07, 2008 | JVC GR D370US camcorder Mini DV
JVC DIGITAL VIDEO CAMERA MODEL NO. GR-D370U
Hi Heidi.
Be sure your camera is on when you have connected it to your PC. Then you have to put it in Play mode and rewind the tape if it's a USB cable you connect with. Start Windows Movie Maker and test.
The following link could be useful http://www.microsoft.com/windowsxp/using/moviemaker/getstarted/default.mspx
Best regards
Estanislao
Apr 21, 2008 | JVC GR-D370 Mini DV Digital Camcorder
JVC GR-D370 Mini DV Digital Camcorder Logo
194 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
