Since it seems to try to start up, what could very well be happening is that the cooling ducts or CPU heat sink could be clogged with dust and dirt, or the cooling fan itself it non-operational. Computer CPUs, if not given proper cooling, can overheat in a matter of a few seconds. Therefore, most will auto-shutdown to protect themselves. Check the inlet and outlet vents and the CPU heat sink for clogs. Also verify that the cooling fans run when the unit is energized.
SOURCE: latitude d505 not charging
If the system runs using the AC adapter, but the battery doesn't hold a charge and the battery indicator LED flashes orange, then replace the battery (A battery with an internal failure may flash 4 times orange then once green and repeat)
The normal lifespan of a PC battery is 300 to 500 recharge/discharge cycles (roughly 12 to 18 months)
SOURCE: My Acer Aspire 5000 won't
hi i just refurbished an acer 5000 laptop..everytime i try to install windows it shuts down after 10% start....i have changed hdrive, memory..etc....
results found same laptop works 100% when installing linux mint !!
go figure ?????
regards tonster
SOURCE: Laptop will not boot. The power light flashes
CLICK HERE
the codes which you see are universal for all the dell laptops. find the appropriate. this will solve your purpose and guide you how to go furthur.
SOURCE: C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen.
Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
SOURCE: Hellow Dear, My acer aspire 4935
First, you need to make sure your power adapter is providing enough
power to both run the laptop & charge the battery. A very good way
to do this is to compare your laptop voltage & ampere requirements
(written on a sticker on the bottom of the laptop) with the voltage
& ampere ratings of the power adapter. Voltages should be the same,
or the power adapter's voltage about up to 0.5 volts more than the
laptop's voltage rating. Amperage of the power adapter should be at
least equal to or greater than the laptop's rating. It should never be
less than the laptop's rating, or else the power adapter will be
providing insufficient amperes to charge the battery. Of course, the
power adapter's nominal amperage might be ok, but it degraded on usage.
You can verify this by testing using a good or new power adapter.
If
the battery did not charge using the new power adapter, take the battery
off the laptop, & using a dry tooth brush, scrub in between the
fins of the battery connector on the motherboard & on the battery it
self, then put the battery back into the laptop & try again.
If
this still did not resolve the problem, then the battery itself could be
bad. Try it on another laptop, or try a good or new battery in your
laptop.
If this did not work, there might be a possibility that the
charging circuitry on the laptop's motherboard is defective & needs
servicing. In order to do this, the laptop needs to be disassembled
& the motherboard checked for defective/burned out components in the
area near the DC jack. Any defective/burned out components found should
be replaced, or you might need to replace the laptop's motherboard
altogether.
