Question about Alpine CDA-9815 CD Player
Understanding the radio
I installed my CDA-9815 but I am having problems understanding all those numbers in the EQ and Cross Over section. Is there any way i could get some help in understanding what each set of numbers are for?
The volume is very low and I am wondering if there is a button or something that controls that. I have to turn the volume to about 19 or 20 to get good sound. Please assist, thank you.
  • 1,224 Answers
Re: Understanding the radio
Equalizer highs and lows of sterio there should audio and entertainment buttons these should be your adjustment
you might need to upgrade the speakers for better quality sound sometimes these old speakers dont put out like everyone wants
Posted on May 07, 2008
0 characters
3 Points
I have a alpine cda 9815 cd player. it has an auxillary input, am i able to add a usb port connector to it? Or what parts should i add so i can play music through usb flashdisk. thanks
there is no option to add a USB port on this model. An alternative to use a usb flash drive is to use a MP3 with the auxillary input. Cheap MP3 with works fine too.
Feb 28, 2011 | Alpine CDA-9815 CD Player
Don t have a problem but i need a diagram how to wire a alpine cda-985 reciever to a kenwood kac-x542 amp in a 74 corvette
how to fit an indirect hot water cylinder from off an rayburn royal .and is it possible to use a pressure cylinder . diagrams would be useful please.
Sep 22, 2009 | Alpine Car Audio Receivers
Can't access some other options/display?
you might have not installed the radio correctly or your car just isnt compatible with that setting on the radio
hope this helps
Apr 02, 2009 | Alpine CDA-9815 CD Player
What can i use the auxillary cable for
yes you can connect it to an ipod/iphone or anything with an aux outlet. Some require an adapter to the plug but it'll still work.
Feb 21, 2009 | Alpine CDA-9815 CD Player
XM Radio Receiver
Go to and type in the search box XM Radio. Walmart carries a XM Docking Station that is capatable with most units. FYI though XM has merged with Sirrus so XXM will still work but will soon be unbuyable.
Jun 18, 2008 | Alpine CDA-7897 CD Player
dont connect the pink/black wire just trouble these are signal interupt lead wires cap and tape off and the orange wire is the dimmer wire for when you turn your lights on and off
May 06, 2008 | Alpine CDA-9815 CD Player
Alpine CDA-7873 (Same as CDA-7876 basically)
the blue line from the radio harness does not have power when the cd or aux are being used and the amp is not turning on-wire the remote line from the amp to the red line and your amp will stay on and you will get sound
Mar 27, 2008 | Alpine CDA-7876RB CD Player
Understanding what the numbers are for
the numbers are frequency settings that filter unwanted freq.
theres is not wrong setting just play with it till your satisfied with the sound.
Nov 14, 2007 | Alpine CDA-9815 CD Player
Alpine CDA-9815 CD Player Logo
158 people viewed this question
Top Alpine Car Audio Receivers Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Jeff Turcotte
Jeff Turcotte
Are you an Alpine Car Audio Receiver Expert? Answer questions, earn points and help others
