Question about George Foreman GR10AWHT Indoor Grill
Whats a fuse for inside the grill ? and if i cut it out what will it blow
Ok thanks
  • 368 Answers
Re: whats a fuse for inside the grill ? and if i cut it...
HI Izzyt,
You don't want to cut any fuses out of an appliance - - they are for safety, and prevent worse things from happening (like burning down your house instead of burning your dinner).
If you're looking for parts or service for a george Foreman grill, go to
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using,
Posted on Dec 30, 2008
0 characters
3 Points
Do Forman grills have a safety cut off if you forget to turn them off
Um, I don't think so. Probably the only way it will shut off is if it blows the breaker.
May 25, 2016 | Electric Grills & Sandwich Makers
Cooking Time fr Chicken breast
a lot depends on the thiknesss of the breast. But if the grill is hot say 200C an average time is about 3 minutes per side. To test do a small cut obliquely to ensure it is white all the way through.
Thanks for using FIXYA
Apr 13, 2010 | George Foreman GR10AWHT Indoor Grill
Foreman gv5 grill just stoped working
There is a thermal fuse in series with the heating coils inside. You will have to disassemble it, find the fuse, take it to an electric supply house and get a replacement. Some soldering "may" be necessary.
Mar 21, 2010 | George Foreman GV5 Indoor Grill
How to us the betty crocker stuff n munch?
You actually don't need to cut the bread into triangles because when you push down and it cooks it, it makes creases so that you can easily pull them apart.
Oct 09, 2008 | Betty Crocker BCF1940 Sandwich Maker
George foreman 10814
The 240 degrees celcius Thermal fuse under the heat proof sleave as blown ...
60pence each from Maplins ...
Aug 26, 2008 | George Foreman 10814 Indoor Grill
Thermal Fuse?
Under the bottom hot plate, remove the screws and open the grill, one of the wires has a heat protective sleeve on it and is held to the casing with a clip, the thermal fuse is under that sleeve, I contacted the manufacturer and they said it was not available as a spare part.
Nov 15, 2007 | George Foreman G5 Indoor Grill
Foreman Grill GR36CB stopped working
Foreman grills have a fuse on the circuit board, have you popped that section open to visually check the fuse? It could be that simple. Fuses do wear down over time, so depending on how much wear and tear you put in, it could just have broken on its own.
Of course, if you replace the fuse and it still goes, you'll need to double-check to see what's shorting it out. The unit may be dead but I wouldn't bet on it.
Nov 08, 2007 | George Foreman GR36CB Indoor Grill
Looking For:
If that's not the exact model, others can be found at:
for parts, call them at:
Oct 21, 2007 | George Foreman GR30 Indoor Grill
George Foreman G5 Grill
With the unit unplugged, check the elements to see if one has become unseated. A gentle push should seat them. Some elements are plug in & can come unseated.
Jan 21, 2007 | George Foreman G5 Indoor Grill
Grill Stopped working
I am having this exact same problem. Did you ever get yours taken care of? I was going to take mine apart and look for a fuse...
Sep 24, 2006 | George Foreman G5 Indoor Grill
George Foreman GR10AWHT Indoor Grill Logo
88 people viewed this question
Top George Foreman Electric Grills & Sandwich Makers Experts
tina gallow
Are you a George Foreman Electric Grill and Sandwich Maker Expert? Answer questions, earn points and help others
