Question about Brother MFC-5460CN All-In-One InkJet Printer
Brother MFC 5460CN No cartridge error
Machine says that magenta is empty, cartridge level reads empty. But when I put a new magenta cartridge in it reads no cartridge open cover and reinstall magenta cartridge. The cartridge is full and is a compatible cartridge not brother brand. I have tried 2 different cartridges and am getting the same error message
  • 3 more comments
  • Anonymous Nov 15, 2007
    Actual when you put magenta, then check the LCD display, now it may be complaining other cartridge being empty as well. replace all the empty ones before it will work. You can leave the ones that the printer does not complain about being empty. Also you can use refill or refurbished inks, worked great fro me.
  • Anonymous Jan 07, 2008
    Same problem. The suggested solution does not work.
  • onalaska Apr 26, 2008
    where can you get a new car holder and can an amateur install it?
  • kerridge Feb 04, 2009
    same problem here, some suggestions in the comments of this page worked for me, 23 and 115..
    http://dan.hersam.com/2005/03/09/brother...
  • Anonymous Mar 01, 2009
    After replacing black cartridge I get message "no cartridge" the black ink cartridge is full.
The tape method worked for me on my 1960C. I put duct tape over the window in the front. If there's a place you can see ink, cover it up.
Posted on Nov 18, 2009
MACHINE SAYS CARTRIDGE EMPTY. HAS NEW CARTRIDGE STILL SAYS THE SAME. I HAVE OPENED AND REPLACED AGAIN. SAME PROBLEM.
Posted on Sep 26, 2008
    Problem Solver:
  • 7 Answers
Third place I'm posting this today... This solution worked for me:
This is a simple fix. This printer uses a LIGHT SENSOR to detect if the cartridge is installed properly. Numerous things can allow extra light to enter... your solution is this:
Get electrical tape (duct tape may be too thick) and cover the rear sides of your cartridge; along with the recessed square shaped area that is directly in the center of your cartridge. Cut the tape so that you can cover this area without impeding the shape of the cartridge (so it can still be inserted and removed easily) I have used this solution to repair this exact problem on MFC-665CW when installing a continuous ink supply (in place of the original cartridges) You can actually just tape the internal sensor and close the front cover if you want to test it without any cartridge at all (though its not a good idea to print like that as I"m not sure if it will damage the unit) Those of you wishing to only buy Black ink can attempt this if you dont care about voiding the warranty or possibly breaking the unit... just cover the other slots with electric tape.
Posted on Feb 21, 2008
  • 832 Answers
Buy a original magenta one and install it. If your lucky the error will disappear.
If not, be sure that the compatible ones have stained the circuit board of the indicator. In that case you need a new cart. case.
Posted on Nov 14, 2007
I have this problem with my 5460CN and read about this taping thing. I just can't figure out where the tape goes! Tried about everyplace I think. Anyone have a photo to show me where the tape goes?
Posted on Oct 15, 2009
MFC-J430W will not recognize any new magenta cartridge!
When installing the cartridges, it is important that you insert them from left to right with the black cartridge first and the magenta cartridge last. The reason for this is because the magenta cartridge has a clip on top of it that goes into the cartridge door sensor. The clip needs to push the sensor in so the printer is able to function with the cartridge door open. If you insert the magenta cartridge first, the printer will think the cartridge door is closed and you will get a error message for the other missing cartridges.
May 29, 2013 | Brother Office Equipment & Supplies
Printer will acknowledge only 3 of 4 new ink cartridges - keeps saying change LC51M
doesn't LC51M refer to Magenta(red) not Cyan(blue). on my J435W the colors goes as follows: BK Y C M LC71 Series cartridges. Maybe you have them switched around? just a thought.
Sep 17, 2012 | Brother MFC-5460CN InkJet Printer
Where do the ink cartriges on a brother mfc 5460cn fo
Your machine is equipped with an ink dot
counter. The ink dot counter automatically
monitors the level of ink in each of the 4
cartridges. When the machine detects an ink
cartridge is running out of ink, the machine
will tell you with a message on the LCD.
The LCD will tell you which ink cartridge is low
or needs replacing. Be sure to follow the LCD
prompts to replace the ink cartridges in the
correct order.
Even though the machine tells you that an ink
cartridge is empty, there will be a small
amount of ink left in the ink cartridge. It is
necessary to keep some ink in the ink
cartridge to prevent air from drying out and
damaging the print head assembly.
a Open the ink cartridge cover.
If one or more ink cartridges are empty,
for example Black, the LCD shows
Ink Empty Black and
Replace Ink.
b Pull the lock release lever down and
take out the ink cartridge for the color
shown on the LCD.
c Open the new ink cartridge bag for the
color shown on the LCD, and then take
out the ink cartridge.
d Remove the protective yellow cap (1).
Note
If the protective yellow caps come off
when you open the bag, the cartridge will
not be damaged.
e Each color has its own correct position.
Insert the ink cartridge in the direction of
the arrow on the label.
f Lift each lock release lever and push it
until it clicks, and then close the ink
cartridge cover.
g If you replaced an ink cartridge, the LCD
may ask you to verify that it was a brand
new one. (For example,
Did You Change Blck?) For each
new cartridge you installed, press 1
(Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge
you installed is not a brand new one, be
sure to press 2 (No).
If you wait until the LCD shows
Near Empty and Ink Empty, the
machine will automatically.
Find this on page 113 of the manual:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002135/cv_mfc5460_usaeng_usr_a.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 04, 2010 | Brother MFC-5460CN All-In-One InkJet...
Machine says that magenta is empty, cartridge level reads empty. But when I put a new magenta cartridge in it reads no cartridge open cover and reinstall magenta cartridge. The cartridge is full and is a...
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Sep 28, 2009 | Brother MFC-5460CN All-In-One InkJet...
Brother MFC-5460CN won't scan because cyan ink empty
Brother is telling us that sometimes the cartridge can be installed too fast causing it not to read. Install it slowly to see if that helps. Also, power down, remove all the inks and power up. Add the inks one at a time when it asks.
Jul 09, 2009 | Brother MFC-5460CN All-In-One InkJet...
Brother MFC-210c-Just replaced ink cartridge & it is already empty
I gave up on this printer and bought a new one from a different manufacturer.
Oct 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc-410cn colour cartridge problem
There may be three problems here.
1.Not doubting your skills for one minute, nor wishing to offend you in any way, but did you remove the protection strip off of the Magenta ink cartridge? Sometimes we forget to do that.
2.Once a new ink catridge is installed, it's best to go to the Brother diagnostic tools section, and run a test. Sometimes an error code is kept, (Ink cartridge is empty), and the diagnostic tool checks this out. It then clears the error code, and 'recognizes' the new ink cartridge.
3.Ink may have dried, for the tiny little holes for the magenta ink cartridge, where it attaches to the body of the printer. Just this one ink cartridge. Suggest you don a pair of rubber dishwashing gloves. MFC-410cn -> Unplugged <- from the surge protector, use a clean, lint free, warm water, damp cloth, and wipe the holes for the ink cartridge, where it lines up with the printer body. This will be where you see that copper metal strip. (Or perhaps it's brass)
To clarify, you are cleaning the printer body. The area where the ink cartridge goes, and the metal strip. The ink passes from the ink cartridge, and goes through holes in the body of the printer. The metal strip is where these holes are located. Allow this area to dry. You may want to use a hair dryer set on low heat to speed the drying process up. Constantly move the hair dryer back and forth. Keep it about a finger length away.
Once you are satisfied this are is dry, reinsert the magenta ink cartridge. Plug the printer back into power. Advise waiting one minute, then turn the printer on.
Use the Brother diagnostic tool.
Should you not be able to find the Brother diagnostic tool, I suggest you go to Start>Hover your mouse cursor on All Programs>Go over to Brother>MFC-410cn>and to the Help section. The Help section, will tell you how to open the diagnostic tool.
Aug 19, 2008 | Brother MFC-410CN All-In-One InkJet...
Black cartridge doesn't print
you need to do a hard reset on the printer as well it might clear up the problem and recognize the ink at its proper levels.
refer to your user manual or let us know and we will find the procedure to do so.
i have a similar model and know how picky they can be.
Aug 03, 2008 | Brother MFC 420CN All-In-One InkJet...
Model mfc-240c
did you replace with brother carts, are you sure machine is refering to mag and yellew being mt, not the other ones, power off, remove all carts, power on , reinsert carts one at a time answer machine when prompted. these cartridges are deemed empty even when they look like they have a little ink left. Try putting in 4 new brother inks
Nov 09, 2007 | Brother Multi-Function Center MFC-240C...
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-5460CN All-In-One InkJet Printer Logo
3,101 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
