Question about Business & Productivity Software
Ms access I want to know basic knowledge of ms access
  • 32 Answers
Re: ms access
Re: ms access
Before this u should know what is databse.
ms access has various objects likw table,form,query,report etc..
table is a object which stores the actual data and form is used to enter the data in to the table and display the data from the table, while report is object which is used to desplay your data in required formate.Query is used to fetch the data from the table in customised formate.for that u should have knowledge of SQL.
Posted on Nov 18, 2007
0 characters
3 Points
Product key
I'm sorry but this is not a warez site...We do not give out activation keys or access codes...
Jun 28, 2012 | Microsoft Office 2007 Basic for PC
Export Word Data to Power Point
Format Word document in following manners:
1. Titles as HEADING1
2. Contents as HEADING2
3. In Office Word 2003
File Menu-->Send to --> Microsoft Office Powerpoint
Now you can see your exported presentation in newly open MS Power Point Window.
Tip: In MS Word 2007/2010 you can add Send to Microsoft Power Point Button to quick access bar as:
Office Button --> Word Options --> Customize --> Enable All tools --> Select Send to MS Office Power Point --> Add --> OK
Now you can follow the same steps in MS Word 2007 too.
Cheers ;)
Zulfikar Ali
on Apr 09, 2010 | Microsoft OFFICE 2003 BASIC OEM ENGLISH MS...
....where to download ms access
Ms. Access is part of Microsoft Office and you cannot download for free.
But you can download Ms Access database viewer from here
Jul 29, 2009 | Microsoft Office Access 2003 (077-02871)...
MS Access 2007 freezes when opening a basic TABLE. Please assist in resolving this frustrating problem.
You might try the "Compact and Repair" database option first before working on the database. Click on the "Office Button", then click on "Manage", then select "Compact and Repair Database". The usage dialog from there is straightforward. One that'srun, try opening the database again and opening the table as well.
Jul 15, 2009 | Microsoft Office Standard for PC
How to create a program using ms access?
you need to study the basics of database programming. take short courses for database programming.
Dec 04, 2008 | Microsoft Access 2002 for PC
MS access 2003 problem
I do not know the pogramme in MS access I know the simple course of MS Access.Please kindly send me full verson of MS Access programme course in my mail Id
Jun 20, 2008 | Microsoft Office Access 2003 (077-02871)...
ThinkDB2 is an easy to use database. Like most Palm databases it is based on MS Access, but no knowledge of Access is needed. ThinkDB allows you to design the Form, such as you see on the left, on the Palm itself. ThinkDB is freeware, but if you want to Sync to your Desktop and therefore to and from MS Access you need to download and pay for their Windows software. This ranges between $20 & $40 depending on which version you require.ThinkDB2 is 350Kb to download and takes 149Kb of room on the Palm. -- SOURCE
Although I couldn't find a 'manual,' I did find that you can get a list of functions in ThinkDB2: CLICK HERE.
Feb 19, 2008 | Business & Productivity Software
Eager To Learning MS Access
The easiest and fastest way to learn the basics of any of the main office programs is with multimedia tutorials. Ranging 5-10 times faster than text. More can be learned in this way in a shorter time.
In regards to VBA, if you only want to work with macros and scripts within an application, a minimal knowlege is all that is necessary. If you are wanting to use VBA across applications, you will need a little more depth of knowlege (at least in my case) is needed. May I suggest Microsoft's 'inside out' series of books. It looks intimidating but you only need the section you are studying.
There is something special about getting tutorials and learning information from the actual program manufacturer. They are the authority and free.
Okay, my suggestion is to first go to Microsofts website and view the tutorials available for your application: MS Office tutorials
Then, if you find your thirst for knowledge unquenched:
  • Third party online tutorials are often quite good. But often the depth knowledge like VBA will turn into a 'tips and tricks' rather than the foundation needed.
  • Get some of the multimedia learning, all it takes is a few 20 minute segments. Titles like Mastering Access 2003 by Magic Media, includes VBA.
Learning some of these applications can be very daunting. It is estimated that your typical user will use only around 10% of the programs capabilities. And they keep adding capabilities! Anyway start easy and work your way up to the complexity you want.
For the other users that have similiar problems, the real answer is to learn the above. But to convert numbers to words you need to redefine the field as text, and enter numbers.
And if you are setting up a search criteria for multiple text boxes using IF condition, it depends on what you are comparing. If you are comparing to a set quantity it would look something like this: IF field/text box = "Fixya" THEN performed action. Endif. If you are comparing two or more text boxes to each other it may look something like this: IF field/textboxA = fieldtextboxB or fieldtextboxC THEN action Else action. Endif
Hope this helps!
Dec 30, 2007 | Microsoft Office Access 2003 (077-02871)...
What are the uses of MS Access??
What are the disadvantages and advantages of MS Access?
What are the MS Access Data Base Objects?
What are the different kinds of toolbars in MS Access and there functions?
Nov 19, 2007 | Microsoft Office Professional 2007 Full...
Business & Productivity Software Logo
173 people viewed this question
Top Business & Productivity Software Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Business and Productivity Software Expert? Answer questions, earn points and help others
