I just had the Mitsubishi Heat Pump MSZ-GE35VAD - installed. It's set on Heat, Auto fan speed and 20 degrees. I notice it continues to pump air into the room when it is at temp. I was expecting it to stop when it reaches temp and restart as required like other heat pumps I have used. Does the Mitsubishi not work like this?
Check to see if you have fan on automatic or continuous run ,it should have a setting so you can get air flow at all times or just when unit runs
Testimonial: "The FAN button is set to the Auto symbol. I cant see in the manual what button or symbol I would look for to know if it was on continuous or not?"
call dealer as if it is set to auto it should shut of after awhile
