Question about Flat Panel Televisions
Neovia 38inch flat screen lcd
LCD 38inch flat screen made by NEOVIA Just over 15months old, sits in stanby mode will not switch on.took the back of to see if I could see anything obvious all looks fine. I have checked the fuse on the circuit board and that is fine, the power goes down to the small circuit board that controls the on and off and channel volume the stand by light is on, but when you press the on switch on the set nothing hapens, I have also tryed the remote nothing, it wont power up, can anyone help please.
you can email me
Re: neovia 38inch flat screen lcd
Maybe inverter board problem or maybe eeprom on mainboard corrupt-i would say inverterboard
Posted on Dec 17, 2007
0 characters
3 Points
Hello.i have a tv plasma neovia neopl4200es but inside is all samsung.i have a problem with the display because i don't have colours with it should be,and the image is a little bit flashing Before was...
Sounds like supply voltage problem to its display panel. Every plasma display panel will have its own Va & Vs voltages; which will be marked at the silk screen on the display panel itself. It might differ from panel to panel. Even a slight difference in these voltages, will cause unexpected display nature. This is true to all Plasma TVs; irrespective of its brand and screen size.
Adjustment to these two voltages are there with its main power supply regulator board. You should be fully aware about these adjustment; I recommend.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Dec 13, 2014 | Flat Panel Televisions
From my experience with sony tv it's normal.The set is going through update mode.Leave the set for about 10 minutes and it should be back to normal.
Jan 06, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Teco 32" flat screen whilst watching my tv the
I would love to help you.
Did you experience any storms recently? IE. the power cut off unexpectedly?
Jan 13, 2011 | Sanyo 42 in. LCD TV
Tv recently started taking a long time to start up , and when the picture shows up it has some runs in it like someone spilled something on it. I turn tv off and back on and no more lines. 52" lcd samsung...
If unit not covered by warranty, you or qualified lcd technician will need to investigate unit's "switch-mode-power-supply" for common (all brands) defects that can be the cause of this type symptom. HAVE YOU BEEN TO YOUTUBE YET???? Go there first!!! Then come back to FIXYA and tell us what you will do. Do your research first, then and only then do a comment and rate this response on fixya. When "very strange" things start to occur with any type (plasma or CCFL) lcd display, the first place I would investigate is the power supply board!! 12fixlouie
Sep 09, 2010 | Samsung LNT5265FX 52 in. LCD Television
Tv is automatically switching to stanby mode after a few seconds
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like, to buy a refurbish power supply board for the replacement.
Hope this helpout......
Aug 03, 2010 | Sharp LC32D44EBK 32 in. LCD TV
Logic lcd tv.switch it on ,goes straight back on standby
Hi my name is Roety,
I can help you with your issue ,
May have bad capacitors on the power supply other than that its a guesswork game 2 main boards and a screen
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Jan 29, 2010 | Flat Panel Televisions
Bush lcd 37 inch tv keeps going to stanby
my bush lcd tv keeps staying in standby mode and wont go on if it does go on its only for a minute or two....
Help please
Mar 04, 2009 | Flat Panel Televisions
LN-R408D Samsung LCD flat screen TV
they must try to repair the smps [puff capacitors]first.then try a master reset thru the service mode.if these steps do mot solve the problem replace the t-con board on lcd panel.
Mar 26, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Mogen tv remote control code
can you please assist us with a Sky setup code for Neovia neo-3775nd.
Jan 05, 2008 | Flat Panel Televisions
Doesnt work
Unfortunately, Protron LCD's are very low quality, mine went out in 15months. Your problem may be similar to one I had & I fixed it by cycling the on/off switch next to where the power cord goes in the back of the TV. Also make sure the power cord is inserted right since the "yellow" light indicate powering up but not full power. Hope this fixes it since I couldn't find ANYONE that services/repairs PROTRON brand.
Nov 12, 2006 | Protron PLTV-26 26 in. HD-Ready LCD...
Flat Panel Televisions Logo
341 people viewed this question
Top Flat Panel Televisions Experts
Jaime Hernandez
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
