On Rancilio coffee machines, the meaning of the green and orange lights can vary depending on the specific model and configuration of the machine. However, in many Rancilio espresso machines, the lights are used to indicate certain states of the machine during operation. Here are some common interpretations for the green and orange lights:
Green Light: The green light on a Rancilio coffee machine typically indicates that the machine is powered on and ready for operation. When you turn on the machine, the green light should illuminate to show that it has power.
Orange Light: The orange light often indicates that the machine is in the process of heating water to the optimal brewing temperature. Once the water reaches the correct temperature, the orange light may turn off, and the machine is ready for brewing.
Blinking Orange Light: A blinking or flashing orange light might signify that the machine is in a heating phase, and the water is being heated to reach the appropriate temperature. This is common during the initial warm-up or after the machine has been idle for a while.
Red Light: Some Rancilio machines might use a red light to indicate specific alerts or warnings, such as low water level, need for maintenance, or other issues
Is unit running? Orange switch - is that the fast freeze switch? If on and running, green light faulty. If nothing happening, start with fuse, test the switch and make sure power is to the thermostat.
SAome have a pad some have a small tray. This cancelled the warning and reset the printer for use.
Waste ink full reset These are the instructions which worked for me on my Canon pixma ip90 bought August 06:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
Is your power box light orange or green. It should be orange if turned off and go green when turned on if it is red your power supply box is no good you can unplug it leave off for 10 minutes or so then try again if light doesn't go orange you won't be able to turn it on. I had the same problem and it was power supply box with red light got new one works great.
