Question about Dell 1600n All-In-One Laser Printer
Dell 1600n: Toner marks down the center of the page.
When printing, the words (or logo) at the top of the paper appear continuously (faintly) down the center of the paper.Toner splotches also.
  • 2 more comments
  • Anonymous Nov 20, 2007
  • Anonymous Dec 03, 2007
    Really bad toner marks from top to bottom of page. Replaced toner cartridge and was fine for a while. Same problem started with the replacement cartridge.
  • Anonymous Dec 05, 2007
    The streaks on my prints look like ghosted/faded lettering from the print job.
  • Anonymous Jul 22, 2008
    Whenever I attempt to scan a document using the automatic feed, I see a solid line that runs down the entire page. If I lift up the door and place a document directly onto the glass then it scans just fine. I'm thinking that it has something to do with the wheel that feeds the document into the scanner. Maybe it gets ink residue on ot or something. Does anyone have any suggestions?
  • Dell Master
  • 1,056 Answers
There are 2 seperate glass areas on the top, the large one is for when you lift the cover to scan or copy, the little narrow one is when you use the ADF. If there is a dot or a spec on the narrow part, it will leave the streak on the page, Clean the narrow part really well. I use a foaming window cleaner, and a razor blade.
You may also want to check to see if there are any small scratches on that glass. That will cause the same thing to happen.
Posted on Jul 22, 2008
Random light grey splotches
Sounds like the high voltage necessary for depositing toner on the paper is acting up.
Feb 20, 2014 | Brother HL-2170W Laser Printer
My HP LaserJet 1300 printer smudges the entire document and the toner is very faint. The cartridge has toner in it.
It means your machine needs cleaning. You can purchase cleaning sheets from the office supply store, and insert it like a regular document, hit print, and the dirt comes off.
Dec 21, 2012 | HP LaserJet 1300 Printer
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Refill toner
check this video it is very easy
i have try 3 times in the same cartridge
and works just like the original
Dec 03, 2010 | Canon LASER SHOT LBP-2900 Printer
Black splotches down the page.
You will have to take the printer to have the fuser unit leaned out. There was most probably a toer spill that got tuck to the fuser.
May 18, 2009 | Konica Minolta magicolor 4650DN Laser...
Ink dots on right side of paper
Toner cartridge? So this is a laser printer? In that case I suspect it is not new? This sounds like old age on the main image drum, that will probably give the exact same mark on each page, correct?
Apr 15, 2009 | Dell 3000cn Laser Printer
Black splotches on paper when printing
either toner cartridge is leaking or the fuser is bad and starting to hold extra toner- any chance of swapping toner cartridge or testing it with another printer (friends?)
laserjet 4+ ?
Apr 07, 2009 | HP LaserJet 4 plus Printer
The problem is: Black splotch on paper
if it is a laser multi function machine, there may be toner build up on the fuser roller. also, there maybe some other component malfunctioning. i.e., print cartridge (if it's one of those "all in one" type deals", toner and/or drum (if sold separately), place a service call
Apr 06, 2009 | Minolta EP1030/1030F CS/PRO Copier
Toner splatter and faint double image
replace the toner cartridge or get the cartridge refilled as its about to empty .
Dec 09, 2008 | HP LaserJet 1020 Printer
Words Copied Multiple Times
Yes Cartridge problem is what causes double imaging 95 % of the time, there is a rubber blade in the drum unit that wears and doesn't clean off old image from drum. Have known this fault to be fuser at times, the way to tell is to get a print to stop half way threw machine by openning door during print, remove cartridge and look at print, you want it to be stop before the fuser(hot bit) but after the drum, image still rubs off if pre fuser and then you can see if defect is present before paper travels threw the fuser, but in your case I think you will find it is not the fuser it is toner cartridge.
Nov 24, 2007 | Office Equipment & Supplies
Dell 1600n All-In-One Laser Printer Logo
321 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
