Cars & Trucks Logo
A
Anonymous Posted on May 18, 2015
Location of all vin numbers on chevy aveo 2006?
My car was stolen and I need to know where are located all vin numbers
Rhonda Webster
Level 3:
  • Cars & Trucks Master 978 Answers
  • Posted on May 18, 2015
Rhonda Webster
Level 3:
Answers
978
Questions
Helped
446909
Points
2917
If you just need the vin number (since your car is stolen) you can locate it on the title of your car.
As for where it is on the car itself, the vin number is located on the upper left hand corner of the instrument panel and can be seen through the windshield.
I can not locate a new obd port and studs is there a reason i have a 2011 chevy aveo 5 LT and it will not read for an emissions test help
Ask at dealers they will know where the OBDII is located ,a car this new should be accessed from under the front drivers side footwell unlike some older europeon vehicles that i work on.Even here now in europe they have started to read OBDII on newer cars but our test has a probe up the tailpipe and measures about 7 different things .I think they are reading the ECU for the chassis number ect ,looking for stolen cars
What is the 2007 chevy aveo engine number
PDF]2006 Chevrolet Aveo - GM Heritage Center
https://www.gmheritagecenter.com/.../gm.../Aveo/2006-Chevrolet-Aveo....
2006 Chevrolet Aveo: Refinements Enhance Value and Safety . ..... Engine NumberLocation . ... Manual Transmission Identification Number Plate (Y4M) .
Vin number location on 2013 ford f350 super duty chassis bodyf
vin numbers can be found on the windscreen , fire wall , inner guards ,chassis rails . They are placed in many positions to help identify parts from a stolen vehicle.. Your hand book will have the locations explained
2answers
Located the VIN and Locate the chassis number in a car Mitsubishi Model 1993 Mitsubishi L300
look on the inside of your Door there will be a metal frame stamped on the inside of it explaining all the serial numbers
2answers
Where are id tags ?
Usually that is on a sticker in the trunk or glovebox.
2helpful
Fuel filter location 2006 chevy aveo
The Aveo gas- filter is located passenger-side rear, in frount of the rear tire.
Where does the brake fluid go in a 2006 chevy aveo?
The Brake Fluid reservoir is located under the hood, driver's side on the firewall. See photo with red arrow pointing to it...
10helpful
3answers
Radio is asking for code
One of these codes will work on '04 Chevy Aveo Radios. Dealer wanted to charge $105 to "uplink to manufacture" and enter correct code. #3241 worked for me.
GM Chevy Aveo Radio:
1156, 1165, 1325, 2145, 2151, 2152,
2253, 2346, 2453, 2654, 3116, 3221,
3241, 3251, 3265, 3346, 3451, 3462,
4136, 4314, 4316, 4362, 4513, 4524,
4853, 5241, 5253, 5312, 5436, 5445,
5624, 5813, 6361, 6451, 6645, 8253
1helpful
2answers
Radio Code
get the serial number from the radio and the vin number from the car and call to the delaer and ask for service deparmet with this number you should be hable to get the code
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
