Question about Toshiba 29L1350U 29" 720p LED-LCD TV - 16:9 - HDTV Audyssey EQ, Audyssey ABX - 3 x HDMI - USB - Media Player
How do I make it a pc monitor?
I had it connected to a Lenovo Windows 8.1 pc. Now display is not right and I don't have the manual to get to the correct settings.
    Genius:
  • 1,187 Answers
SOURCE:
How do you turn off lvt
To remove LVT (Lenovo Vantage Technology) on your Lenovo computer, follow these steps:
  1. On the Start menu (for Windows 8, right-click the screen's bottom-left corner), click Control Panel, and then, under Programs, do one of the following:
    • Windows Vista/7/8: Click Uninstall a Program.
    • Windows XP: Click Add or Remove Programs.
  2. When you find the program "LVT" or "Lenovo Vantage Technology", click it, and then do one of the following:
    • Windows Vista/7/8: Click Uninstall.
    • Windows XP: Click the Remove or Change/Remove tab (to the right of the program).
  3. Follow the prompts. A progress bar shows you how long it will take to remove LVT.
Hope this helps!
Aug 25, 2014 | Lenovo ThinkCentre Computers & Internet
How do I retire a Signal out of Range error message?
Go into HP screen menu and turn off the display notification
May 04, 2014 | Lenovo Computers & Internet
How do i switch to external monitor
Virtually all IBM and Lenovo ThinkPad and ThinkCenter laptops allow you to hook up an additional monitor or projector to the computer. When you add an external monitor or projector to your notebook, you can choose to view the display on the computer, on the external device, or on both the laptop and the external monitor or projector at the same time. Toggling between viewing devices is as simple as pressing a couple of keys on the keyboard.
Shut down the laptop. Plug the VGA monitor cable from the external monitor or projector into the blue VGA port on the back of the computer. Turn on the external monitor or projector first, and then the Lenovo laptop. Allow the notebook to boot into Windows normally. Press the "Fn" and "F7" keys at the same time to switch the display from the laptop to the external monitor or projector. Press the "Fn" and "F7" keys again to enable the display on both the laptop and the external display device. Press the "Fn" and "F7" keys again to display screen contents only on the laptop LCD. choose support you need http://www-307.ibm.com/pc/support/site.wss/MIGR-54305.html http://www-307.ibm.com/pc/support/site.wss/MIGR-4YQHUC.html enable tv out on thinkpad http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58625
Feb 13, 2013 | IBM Lenovo 3000 N200 PC Desktop
Monitor looks like right half blue shade
Either your monitor or the video card inside the computer is going bad. To isolate the problem connect another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok that means your video card is ok, but your original monitor is bad. If the Borrowed monitor displays the same blue shade then your video card inside the computer is bad.
Jun 05, 2012 | Lenovo Computers & Internet
I have a NEC laVie LC800j/8 laptop and i have installed windows Xp SP3 recently. but it have not any sound.it is necessary to say that the laptop is safe quitely and prior OS have been Windows XP SP1. what...
I have a Lavie e Lc500/3 model laptop.But few days ago monitor don't display anything but i connect another monitor with laptop external vga port that time monitor work properly.
Apr 07, 2011 | NEC LaVie S LS900/8E Notebook
I need to replace the display on my Lenovo Ideapad Y550P. Is there a service manual that I can get my hands on? Thanks! Don
Hi
If you follow this link it should take you to the website go to support type in your make model and operatings system eg:- xp or vista or windows 7 then search for the manual
http://www.lenovo.com/uk/en/
good luck
please let us know if this was helpful
Jan 24, 2011 | Computers & Internet
My laptop model is lenovo 3000 g430, as my laptop is turned on the screen goes on blinking....pls help me...tell me the solution.
1. Check your power cord & adapter. 2. If its working then check the battery, reseat the battery & check. 3. If available then check with another battery 4. If no, then remove the battery & switch on the PC in AC mode. 5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard. 6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall. 7. If still no display, connect an external monitor, check if display is comming. 8. If Display is coming then your LCD need to replace.
Aug 23, 2010 | Lenovo Computers & Internet
Lenovo ADD2 DVI-D Riser Card display issue
No, not really you just need to move and/or setup any video for the monitor you want to be displayed. You are doing everything right except assigning which folders or files need to be seen on which monitor. all of this can be done within the properties manager for the video. Depending on your system this can be located just about anywhere in the dialouge box. But, you should be able to drag and drop what files you want to display. I this was helpful because you are on the right track. Also visit the Dell tutorial for more information with streaming video to watch and you will be alright after that. If not contact me here.
Good Luck
Fehdi
Mar 12, 2009 | Computers & Internet
Monitor went blurred
If the monitors works well on a different computer then is either the video card or the video cable try using a different screen and cable. eventually change display settings in windows (from control panel. Put them to lower resolution and connect back your display.
Cheers
Feb 16, 2008 | Lenovo 3000 J115 (7387-A11) Desktop...
Toshiba 29L1350U 29" 720p LED-LCD TV - 16:9 - HDTV Audyssey EQ, Audyssey ABX - 3 x HDMI - USB - Media Player Logo
46 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
