Does it beep when you switch it on at the wall
Are there any lights showing on the display when you push the power button? or does it seem completely dead
replace batteries. While holding the light button, turn the wall switch go and off one or two times. You should hear a slight beep and the remote reacquaints itself to that receiver.
Jerry, from what you said, I assume you have a remote controlled ceiling fan. If that's the case, check the batteries in the hand held and the receiver, to make sure they are charged. Also, make sure they are installed properly. The Owner's Manual should have a reference to setting or resetting the codes for the remote control (Hand Held & the Receiver). Check those to make sure they are matching. And don't forget, the wall switch must remain ON for the fan to work, even with the remote control. The remote simply overrides the wall switch, when in operation. You may have to use the pull chain to start the fan motor the first time, then the remote can take over from there.
Good luck. I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
mcdevito75 here, The lights should work when the wall switch is turned on, You may have to remove the wall switch cover to check the color of the wires and then the cover just at the ceiling of your fan, follow the fan wires from the pull switch for the fan, since the fan works you don"t have to worry about those wires, just the others for the lights, match the color codes, from the wall switch to the light wires. You may have a RED from the wall switch and red from the fan, hook them togethet then the black or white wires. You may not have a red from the wall, rather a white and blck. Make sure wall switch is off and or fuse / circut breaker is off while working on the se wires.
I would look for the CMOS reset jumper on the motherboard, if there is one, and while PC is off take of the jumper, then put it back in place. But the more easier option is to just simply remove the CMOS battery from the motherboard, unplug PC completely first, leave it out for a few seconds, then replace it. If that works, you may come across some operating system start options to start the os, depending of what version you have make sure you select the Delete sleep mode data/hibernation data(something along those line), and start OS normally. By the looks of it you've tried everything possible, but last resort would be to try the resetting CMOS/removing CMOS battery. If all fails, try testing using a different power supply.
