Question about Aiwa HV-MX1 VHS VCR
Belts for the HV-MX1
Does anyone know what size belts (3) this vcr takes?
Thanks
    Sergeant:
    Champion:
  • 298 Answers
I am assuming you dont have the old belts
You must determine whether the belt is flat, V, or square
Use a piece of string to measure the length by placing string
in the pulleys,flywheel (the belt will be smaller than your measurement so you wil want a belt 1 or 2 sizes smaller
go tohttp://www.mcminone.com./ with your measurement
and the may be able supply the belt
this site may have a schematic or photocopy that
shows belt part# http://www.servicesoftware.com/sams.asp
hopes this helps
Posted on Nov 16, 2007
    New Friend:
I uses three belts
U-0037-497-U Drive belt
U-0037-511-U Loading belt
U-0037-533-U FL belt
Posted on May 29, 2013
Will Aiwa HV-MX1 Playback Extended Play (EP) Speed?
Probably not then, but you could try a tape recorded at EP.
Jan 05, 2013 | Aiwa HV-MX1 VHS VCR
My HV-MX1U is definitely over 14 years old and was one of the best electronic devices I ever bought. Nothing was ever replaced or fixed in it so, obviously whatever parts like belts or etc need to be...
Probably both. There is a mode or position switch that tells the processor what position the deck is in. If that has failed that could be a cause also 14 years for belts is a very long time. You may find a kit on fleabay but switch wise, I doubt it.
Mar 24, 2017 | Aiwa HV-MX1 VHS VCR
Starts to play a tape then shuts down
Hello
Video casette is not moving normally. It struks at the take up spool. Check the belts. OK.
Feb 12, 2011 | Aiwa HV-MX1 VHS VCR
Aiwa HV-MX1: tape won't eject from VCR and it switches off.
Turn over the VCR. Unscrew the base. You will see the 3 belts. Turn the rightmost belt clockwise or anticlockwise (don't remember) but you will see the tape hold mechanism moving down. Once it is all the way down, you can eject the tape out.
You may need to replace one or all 3 belts. This is being caused by belts being loose.
hope this helps.
Sep 22, 2009 | Aiwa HV-MX1 VHS VCR
AIWA VCR model HV-MX1problem
with the unit unplugged take the case off and look on both sides of where the front of the tape would set, you will see two towers, one is a light and the other a receiver,check to see they are plugged in and not obstructed.Also there is a switch that the tape pushes when its all the way in which might be stuck,click it a couple times with your finger.This might help, there are other more complicated things which could cause this problem but mechanical problems are more likely.
Jan 15, 2009 | Aiwa HV-MX1 VHS VCR
Picture gets bad after playing a while
Just the usual problem of needing the rubber belts replaced.
They last about 6 years normally so you are overdue.
Buy a kit of belts for your model from all kinds of sites on the net and install them yourself if you are handy with delicate mechanisms.
Hope ya fix it!
Jan 14, 2008 | Aiwa HV-MX1 VHS VCR
Video cassette
Take the top cover off and watch the mechanism move, usually you can see what the problem is if you get to know its motion. Best if you learn this before it develops a problem of course.
Jan 03, 2008 | Aiwa HV-MX1 VHS VCR
No electricity to the VCR
have you checked the fuse in the plug these can be brought cheap and easy to fit if you have allready changed this one then it is probably the one inside the video if you take the case off when it is unplugged and follow the power lead where it goes into the video you should see a glass fuse the same size as the one in the plug these can also be brought from a tv repair shop take the old one with you they will test it for you and should be able to give you a replacement hope this is some help......................
Oct 21, 2007 | Aiwa HV-MX1 VHS VCR
Tape stuck in VCR
more than likely one of the belts has broken
Oct 12, 2007 | Aiwa HV-MX1 VHS VCR
Aiwa HV-MX1 VHS VCR Logo
559 people viewed this question
Top Aiwa Televison & Video Experts
romy sibug
romy sibug
 Grubhead
Grubhead
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
