SOURCE: 1989 Jeep Cherokee - Electrical Problem - horn, brake lights, blinkers, radio/cd...
There could be a fusible link under the hood off the starter relay that is burnt out.
SOURCE: No brake lights on 96 yukon
The brake fuse #1 is located inside the truck below the steering column. I am assuming you have verified there is 12v power at the fuse & thru the brake lamp switch (orange wire power in & white wire power out, when pedal depressed) at all times. After the brake lamp switch , power goes (white wire) to the Turn signal/hazard lamp switch & out (dark green wire-rt brake lamp & yellow left brake lamp)
SOURCE: All of the brake lights are out on my 2005 xterra.
The brake light circuit is fairly basic:- 12V supply, stop sw, (optional relay), then stoplamps to ground.
See for a free manual download:-
http://rapidshare.com/files/54634249/OfficialXterraManuals05.zip
Testimonial: "I appreciate the literature but am still not sure why all the tail lights work but none of the brake lights do. I have checked fuses, bulbs, switches"
