Question about Pioneer AVIC-N2 Car DVD Player
Not getting power to the rear amp - Pioneer AVIC-N2 Car DVD Player
My car battery went flat and had to jump-start. I have a mono-block that plays a sub-woofer and a 4-channel that plays 6 x 9, after the car started I couldn't get the sound from all the rear speakers
Are all the rear speakers running off the 4 channel? And does the amp show a power on light anywhere? If all the rear deck speakers run off the 4 channel, it might only be a blown fuse. But if you have it all staged with 2 up front and 2 in the rear, the amp may have blown the rear channels. Next option is - did the positive connection to that amp run straight off the battery terminal and does it have a solid connection? Might be a simple mechanical failure (broken connection) Things to remember - some amps have inbuilt fuses, others have breaker protection with reset buttons. Start with checking the power from the battery and work back towards the amp.
Sep 12, 2018 | Car Audio & Video
On my 2004 trailblazer i have no power at my power fuse under the rear seat there is also no power for the 4wd ans brake fuses what do they get there power from
no power at my power fuse under the rear seat ??? Do you mean the whole rear fuse box is dead . Or just a single fuse ? What number fuse an how many amp's ? Under hood fuse box I/P BATT fuse number 48 125 amp ,this power's the rear fuse box.
Nov 18, 2017 | Seat Cars & Trucks
How intelligent is Pioneer's vsx amp/rec "power off" protecting mode? Hi, I would like to have an answer to the foregoing title in order to find out if it's worth repairing my Pioneer...
When you remove boards, you may be breaking a circuit somewhere that is causing the shutdown. Pioneer uses rear panel jacks for ground points a lot, and if even one of these screws is out it can cause it to shut down.
Sep 26, 2013 | Audio Players & Recorders
Panasonic TH-P50X50Z tv has no power after turning off mains switch then turning back on again
ive had this issue many times since buying my same model tv..i leave unplugged for 3-4 days..plug bk in and usually sweet to go again..
Nov 24, 2012 | Televison & Video
Which speakers (Front/Rear) to buy that match Kenwood KAC-M846 4/3/2 Channel Amplifier.
I don,t no where you are reading thease articles from,I installed car audio equipment for over 40 years, Untill i retired a couple of months ago, Who ever is writeing those sort of articles does not have the slightest clue what they are talking about, It is the opposite way around, It is allway better for yor (Speakers) To handle more power then what your amp puts out, Then you will not blow the spaekers, It is best to get speakers at least 20 watts more then what your amps maximuin (RMS) Watts are, Hope this helps you out, (PS) 50 watts (RMS) Is what most people go for, It is in no means (Under) Powered.
Nov 05, 2012 | Kenwood Kac-m846 4/3/2 Channel Amplifier...
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
May 23, 2011 | 2005 Jeep Liberty
Fusebox diagram
hi, this is courtesy of ask me help desk...
FUSE PANEL INTERIOR
1 - 20 Amp (Yellow)Power Antenna Relay, Trailer Tow Relay.
2 - 15 Amp (Blue) Brake Lamps.
3 - 20 Amp (Yellow) Hazard Lamps.
4 - 15 Amp (Blue) Security Lamp.
5 - 15 Amp (Blue) Interior Lighting.
6 - 15 Amp (Blue) Security Alarm Module.
7 - 15 Amp (Blue) Security Alarm Relay, Security Alarm Module, Flash-To-Pass.
8 - 15 Amp (Blue) Overhead Console, Keyless Entry, Radio Memory, Clock/Chime Module, Power Locks, Power Mirrors, HVAC & VIC.
9 - 20 Amp (Yellow) Rear Wiper.
10 - 15 Amp (Blue) Radio Accessory.
11 - 15 Amp (Blue) Cigar Lighter.
12 - 15 Amp (Blue) Parking Lamps, Automatic Headlamps.
13 - 20 Amp (Yellow) Horn Relay.
14 - 20 Amp (Yellow) Power Lock Relays.
15 - 3 Amp (Violet) ABS Module & Relay.
16 - 20 Amp (Yellow) Turn Signals.
17 - 7.5 Amp (Brown) Heater & Air Conditioning Module.
18 - 15 Amp (Blue) Air Bag Module.
19 - 15 Amp (Blue) Interior Mirror, Auto Headlamps, Overhead Console, VIC/GDM Module, Heated Rear Window Relay Coil, Illuminated Entry Relay & Chime Module.
20 - 10 Amp (Red) Heated Rear Window Switch, Overdrive Switch, Speed Control.
21 - 15 Amp (Blue) Cluster, Security Alarm Module, Lamp Outage Module.
22 - 15 Amp (Blue) Air Bag Module, Speedometer, Tachometer, Telltales, Gauges.
23 - 15 Amp (Blue) Heated Mirror Feed, Heated Rear Window Switch.
24 - 7.5 Amp (Brown) Instrument Panel Illumination.
25 - 30 Amp Circuit Breaker Power Seats.
26 - 30 Amp Circuit Breaker Power Windows.
27 - 10 Amp Circuit Breaker Security Alarm Module, Front Wiper.
28 - 30 Amp Circuit Breaker Heated Rear Window Relay
Nov 27, 2009 | 1993 Jeep Grand Cherokee
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
Need wiring color code for power &speaker
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Aug 25, 2009 | Sony CDX-F5710 CD Player
Pioneer AVIC-N2 Car DVD Player Logo
70 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
