Question about Samsung Digimax S630 Digital Camera
Lens won't go in or out, will still take pics
  • brokencam Nov 23, 2007
    daughter dropped digi camera and the lens wont go in and screen says zoom error the part of the lens that is the farthest out is tilted up a bit
  • gizo Nov 27, 2007
    same thing it wont go out! how do i fix it
  • 75 Answers
Power reset your camera by removing the batteries for a minute and inserting it again.
If that doesnt work, consider sending your camera to service center.
Posted on Nov 30, 2007
Canon power shot SD1200 IS elpf won't retract
This is a delicate operation but you can try this: tap the camera lens up on a towel over a hard surface (counter top or floor) while you expect the lens to retract as in turning off. It may be enough jarring force to get cams back in the helix that moved the lens. Hit it hard and flat. IF that doesnt work, try tapping the lens down while it tries to retract. I have heard that people get so frustrated with it that they slam the camera lens up on a desk and that fixes it!
Jan 30, 2018 | Canon PowerShot SD780 IS / IXUS 100 IS...
Camera won't take pics on any setting but 22. Gives
Were you about to say it says FEE on any other setting? This is perfectly normal for a lens with an aperture ring. Leave it at f/22. You control the aperture from the camera body, the same way with a lens without an aperture ring.
If you need a manual, you may download a copy here.
Mar 04, 2012 | Nikon N75 35mm SLR Camera
I deleted all pics from A540 but ended up with "no image" message on black screen. The shutter won't open either. It appears to be stuck in viewing mode.
hi,
first: be sure the battery is full charge.
second: by a compressor try to blow around the shatter and lens .
third : 3 or 4 times try to inflict a blow on the lens by your palm .
at the end see the result
good luck
gorbesia
Jun 15, 2011 | Canon PowerShot A540 Digital Camera
LENS DOES NOT RETRACT NOT TAKING PICS
Try to hit the side very gently while switching ON the camera. Do this several times, It should reset the timing of lens.A little bit of more pressure can be applied while it is hitted. If does not reset, then the timing lens gear is damaged. Take it to qualified service technician to get full service. Thanks.
Apr 30, 2010 | Kodak EasyShare MD853 Digital Camera
I want to add lens to my fujifilm s5600 to take better pics
There are lenses available to add with an adapter ring. I have the wide angle lens (which I LOVE) and a 2x telephoto lens. The wide angle lens allows me to macro from several feet away. It is an amazing lens. The telephoto lens is something you really need to use with a tripod. But yes, there are lenses you can add to your camera.
Dec 16, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Lens Errors 17 & 27 on Sanyo VPC-E760
My camera was showing lens error 12&25 and then shutting off. I tried gently trying to twist and pull the furthest out part of the lens and it popped back into place easily. It made a noise when it did this, and then i turned the camera off, and the lens went back in!! Completely fixed now!!
Aug 03, 2008 | Sanyo VPC-E760 Digital Camera
Panasonic Lumix DMC-TZ3 Lens Won´t Open
This is a common problem with TZ3s. Power the camera on, then puff a little graphite onto the lens cover and coax it open with a tooth pic. Do this, powering the camera on/off till lens opens normally. Add little more graphite if necessary, but sparingly.
Graphite is used because it is extremely slippery, but will not attract dust like an oil will. At the same time, it is black! so you don't want to use anymore than absolutely necessary make lens work. Even then, check to be sure lens itself is clean after, and wipe carefully with an Eyeglass lens cloth only if necessary.
Another option in to remove the lens cover altogether by just pulling the leafs out of the camera. Another option is to sell your working but lens cover problem to a repairman on ebay, and buy a good TZ3 or TZ5 on ebay used, refurbished or new. Good prices if you bide your time.
Don't put in your best bid to the very last minute of the auction. In the mean time, put a camera you are interested in on your MyEbay Watch list and set a reminder alarm on your cell phone about 5 minutes before the auction is to close, then if the price is still good, enter your best bid 30 seconds before the end of the auction. Refresh the auction page on your PC to keep track of the bidding right up to the last 30 minutes so you can see the last remain bid and if it is worth outbidding on this camera. Again, if you are not in a hurry and bide your time, you can get a great buy. There are plenty of these cameras sold every day.
Jul 27, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Action pics with a long lens
What you are experiencing is not blur, its camera shake. You are shooting in low light so the shutter speed is being reduced by the camera's automatic features. Also the longer the lens (the farther you zoom), the higher the shutter speed you need. Even for non moving objects or when panning the shutter speed should be at least one stop above the focal length. ie - 300mm lens = 500 or 1000 shutter AT LEAST! (and don't forget, if its a film lens on your rebel, thats actually 300mm x 1.6 =480mm, so 1000 shutter or higher min.) Moving objects require even faster shutters. Solutions: Get faster (also called brighter) lenses which can be pricey. In low light use higher iso settings in the camera menu. Shoot in either manual or Tv mode and choose the higher shutter speeds while using the light meter to decide aperture. Use wider angle lenses or back off the zoom and move closer. Stabilizers built into the lens can steady the shot by two to four times as well.
Sep 14, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Casio exilim ex-24u
more than likely you will have to send it in. I don't think there is anything that you can do to fix that at home. If the pics still come out ok you can live with it. If pics get blurry then you will have to send it in.
Apr 08, 2007 | Casio Exilim EX-Z4U Digital Camera
Samsung Digimax S630 Digital Camera Logo
64 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
