Question about Unitech (K2724U) Keyboard
Keybord unitech k2724 b
My magnetic reader stop working . Could you help with this issue ?
thank you
0 characters
1 Points
Unplug the keyboard. Use an air duster to clean dirt/dust/particles out of it. Plug it back in and try it. If that doesn't work, go get a new one.
Good Luck
Feb 10, 2015 | Unitech UNI-K2724-B (Note: Keyboard is...
Lenovo Laptop 3000 N100: When Pressing some keybord characters it gives additional characters for example: Pressing on "n" gives 6n, pressing on 5 gives 5b. Thanks.
Hi doronzl,
As soon as you turn the computer ON press and Holding down the FN key+the Num lock key, if this does not work uninstall all Lenovo programs such as ooVoo, IDvault, Lenovo Easy Share, Lenovo Guarded ID, and also uninstall Lenovo Readycom, FYI after uninstall Lenovo Readycom it will restart your computer, that is OK. OH yeah try uninstall the Lenovo Smile Dock as well if you have that it will only give you a smiley face on your desktop and nothing else.
You do not need to uninstall Lenovo Veriface if you have that, No need to uninstall Lenovo Easy Camera or Lenovo Cam suite which ever you have, No need to uninstall Energy Management.
If still the issue is the same I suggest that you restore that machine back to factory defaults to see if the issue will still be the same if it will be the same then this is going to be a keyboard problem and needs replacing.
I hope this Helps.
Have a nice day,
Jul 08, 2011 | Keyboards & Mice
My keyboard stopped working
check ur keybord by fixed it to another computer if it work contact a computer hard ware michanic as the problem with ur cpu.if it doesnt work change ur key bord
Dec 18, 2010 | Sylvania Fellowes 9893501 Microban...
Hello i hope u 'll be fine.... thanks for usingfixya.
  • Press F5 button. it usually 4 refresh.
u can also download user guide for your keyboard.
To download just click on this link, Download Manual
Download it and Enjoy
You can also see lots of effective information of your keyboard from this.
  • Manual guide is in pdf format if you have no Adobe Reader software which support pdf files then Download it from here Adobe Reader
I hope this solution will helpful 4 u. Best of luck
Please do rate if it is helpful
THANKS & Keep using fixya
Feb 13, 2010 | Microsoft Wireless Desktop 3000 Keyboard
Keyboard suddenly didnt work
First make sure battery works fine .
Reattach battery .
Then uninstall wi fi keybord driver.
Then reinstall from disk which come with keybord when you purchase.
Installing driver fix keybord problem .
Let me know if you need further assistance.
Oct 28, 2009 | Belkin F8E206 Keyboard
Keys on left side of keybord do not work
if you have a laptop with special keys left of the keyboard, you may need to install drivers and or software for them, look for them at the makers website the the brand and model of the laptop or keyboard.
if its a special keyboard look for its drivers and software at its makers website.
also if after all that the problem is still not solved make sure hid input service is enabled.
info on the service:
how to turn it on or check its status
press the windows key and R key at the same time or windows key first and then r.
in run menu write in services.msc
presss ok or enter
in services look for HID input service or similiar make sure its started, right click on it and select properties make sure its set on automatic start up and start the service if its stopped with the start button. Apply, close ok. should work.
May 20, 2009 | Compaq Keyboard
Won't scan credit card
You didn't indicate what you are attempting to scan to, but the scanner won't just "scan" the card, it will send the data it reads to an application that is monitoring the connection from the scanner.
Verify that the scanner drivers have loaded properly and then make sure that the capture application is running and looking for the scanner connection.
May 12, 2009 | Unitech POS Keyboard K2724 (K2724-B)
Logitech Mouse V320 Corless Optical Mouse not working
The warrenty period is usually a year. Is there a connection button on the receiver as well? Normally you need to press the connect button on the mouse, and then on the receiver shortly there after. If you want to replace it, you might have an easier time just getting a new mouse.
Jan 25, 2009 | Logitech Cordless Mouse
Mouse and keyboard are not working
whats deeep freeze software ? what brand mouse keybord u have with what os ? thx nick
Jan 07, 2008 | Keyboards & Mice
Compaq Presario v2405us Laptop keyboard help
yes u can remove keybord cheak loose connectons also FN button did u hitthat to stop keybord from working sumtime sthat doe sit hit fn button and try sum keys u can replce the keybord pretty easy get part on ebay install it yourself im open for chat thx nick helpap in saginaw michigan
Jan 07, 2008 | Compaq Keyboard
Unitech (K2724U) Keyboard Logo
29 people viewed this question
Top Unitech Keyboards & Mice Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you an Unitech Keyboard and Mice Expert? Answer questions, earn points and help others
