Question about Vacuums
Bissell shampoo How you change the belt on the shampoo bissell
  • catm45 Apr 27, 2009
    bissell powersteamer clearview model 8806-1. (change brush belt)
    President:
  • 1,673 Answers
I am assuming this had a flat and a cogged belt, if not then provide the model number.
First take off the cover on the left side oif the top cover, then turn it over, remove the screw holding the red lock and pull the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together.
Posted on Feb 13, 2008
  • 17 Answers
SOURCE: how to change belt on bissell proheat powersteamer
Following in a link to the owners manual. This covers some information regarding the belt. From the manual it says instructions should of came with the belt. Hope this helps.
http://www.bissell.com/images/UserGuides/7901_207.pdf
Posted on Jun 27, 2008
SOURCE: directions for Bissell upright rug shampoo vacuum
need belt on brush
Posted on Sep 30, 2008
  • 29 Answers
SOURCE: Bissell steam cleaner will not spray shampoo
My Bissell stops releasing shampoo when the handle is lacked upright, when there is no water in the tank (the most common cause of this issue), or when water is not flowing through the machine because the sprayers are clogged.
Make sure the shampoo container grommet is releasing properly when you press the trigger. To check this, remove the shampoo tank from the Bissell, stand over a sink, and use a finger to push up inside the grommet on the shampoo container, the part of it that mates with the rest of the Bissell. Shampoo should dribble out when you do this. If it won't, the grommet may be clogged.
Posted on May 29, 2009
Vac Belts
  • 701 Answers
SOURCE: How do I replace the brush belt on my Bissel proheat plus shampoo
Here is a link to the manual and a link to the belts that you need for your model:
Bissell Pro Heat Plus User Guide
Bissell Pro Heat Plus Replacement Belts
Posted on Nov 06, 2009
heatman101
  • 43501 Answers
SOURCE: i have a Bissell PROheat
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
f
Posted on Sep 30, 2010
Bissell shampooer 1697-W. Will not dispense water to shampoo carpets....
That means that the pump belt is worn and needs to be replaced. Here is the belt you need and a manual you can view:
Bissell Proheat Belts and Manual
Dec 13, 2009 | Vacuums
Rollers don't turn and pump doesn't put out any shampoo or rinse water
You need to replace the Pump belt and the roller brush belt. You can get both belts and view the manual which has instructions here:
Bissell Proheat Replacement Belts and Manual
Nov 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
May 29, 2009 | Bissell 7950 ProHeat Upright Wet/Dry...
NO WATER COMING OUT FOR SHAMPOOING /DUMPS WATER WHEN UPRIGHT
there is a belt inside that runs the pump to spray the water. I would take it in a have it replaced. Mine did the same exact thing.
May 25, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
I dont know how to change a shampoo pump on a bissell shampooer. Do you have instructions for me?
I need instructions how to change a shampoo pump on a 8910 bissel floor cleaner
Apr 01, 2008 | Bissell Vacuums
Vacuums Logo
315 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
