Heating & Cooling Logo
Robert Posted on May 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Indoor blower wont come on when a/c kicks in has a 2 wire stat that controls heat $ cool red & white wire only
tractorman44
Level 2:
  • Expert 484 Answers
  • Posted on May 16, 2015
tractorman44
Expert
Level 2:
Answers
484
Questions
Helped
205780
Points
843
  • You must not be looking at the cooling stat Robert. Your system sounds like it is an old two-thermostat system because a two-wire set up cannot in any way control both heating and cooling functions of a HVAC system. Look for another thermostat hiding somewhere and you should find a cooling only stat that has three wires connected....R(ed), Y(ellow) and G(reen) terminals. Once you locate the correct stat, you'll peobably still find the actual problem in the air handler. Sounds like the fan relay is not starting the fan motor.
Indoor blower wont run on cool cycle
sounds like a wiring problem. the t-stat fan on position uses high speed on fan as does the call for cool. possibly a bad t-stat.
Hi I have a hb2400vd2m20 air handler and need to know what wires are needed to hook up to my thermostat its a Honeywell, as of the moment there is no heat pump it just the air handler running. I know there...
Honeywell 5000, 8000, 8000 iaq, prestige, round dial analog, digital Honeywell redlink. 1 heat 1 cool thermostat 3 heat 2 cool thermostat. does the stat u have do conventional a/c and heat pump. red wire is hot wire 24 volts not heating its your 24 volt control power. this will be r on your board and t-stat and red wire. y is for cooling mode and is yellow and will be noted y on both board and t stat. green is fan on the indoor furnace and will be g on board and t-stat and the wire is green. blue is the common side of the transformer labeled b on both board and t-stat. I did not see brown on your schematic I looked up I seen orange which is your reversing valve wire for the heat pump whether its calling for cooling or heat this is what changes the flow of Freon to make it to the indoor coil as warm Freon or cold when called for in heat or cool. the thermostat if a vision pro 8000 needs to be programmed in the installer mode which if this is the t-stat u have u need to read through the heat pump section. the green hooked to the orange doesn't look right on the print but that's the breakdown. http://www.manualslib.com/manual/277678/Haier-Hb2400vd2m20.html?page=11#manual heres your schematic
Honeywell tstat not working in auto cool mode
so with system setting cool/ fan setting auto, the condenser runs but the indoor blower does Not? but when system setting cool /fan setting on, the condenser runs and the blower runs?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
I installed a new Honeywell Programable thermostat, When I turned on the AC it turned on the Heater... I followed the wiring but some of it is not making sense... G=Green, Y=Yellow, R=Red, C=Blue,...
Hi, the problem is you have bought the wrong thermostat for the unit if it is not a heat-pump. A heat pump will have W-1, W-2 for heat strips, and Y-2 is for 2nd stage cooling. G is Green for Fan, R is Red for Power, Y is Yellow for cooling, and W would be for Heat. This is all you need if you have gas heat, Orange is for a reversing valve for a heat-pump, and the blue is also for the reversing valve on a Rheem heat-pump. The stat you need will have these terminals, if you are sure its not a heat pump, which I am sure you would know. The stat you need has these terminals. RC and RH. It will have a Red jumper wire connecting the 2 terminals. This is where the Red wire connects, to either one, as they connect together. Connect G to Green, Y to Yellow, and W to white. Since you only have one control transformer, that's why the stat has RH for Red Heating, and RC for Red cooling tied together. Just hook the red coming in to either one. You need only, R, G, Y, and W, to run this unit. Look at your old stat and check the terminals. A heat-pump, uses many more conductors to operate it. O or orange for the reversing valve, blue also depending on the unit. C for common, W1 for stage one heating, W2 for stage 2 heating, Y1 for stage one cooling and Y2 for stage 2 cooling. This stat is used for a commercial unit with multible stages of heat and cooling. If you have a common wire and no batteries on the old stat, go to the indoor unit, remove the panel, and see if you have a common wire hooked up, such as the brown, black, or maybe blue. If so, you will need to hook it up at the stat if it has a C terminal. If it has batteries, just take all of the extra wires and shove them in the wall. You won't need them. Just the R, G, Y, and W, and you will be back on line. Very easy.
Please rate me. Take it back and have them sell you the right stat. Please keep me posted and I will be here if you need my help. Thank you for using Fixya.
Shastalaker7
A/C, and Heating Contractor
I need a wiring diagram for a starndard residential split a/c system. Just the outdoor section is fine.
Hi, if this is just a split standard heating and cooling unit, and not a split heat pump, all you need to do is pull stat wire from the indoor unit control board to control the condenser with 5 conductors, but you will only use 2 wires for the control of the condenser. Normally, the red and white tie to the 2 control wires of the contactor. Back at the control board, red to red and white to the Y or yellow terminal. You will also need to set your disconnect box for your high voltage near the condenser, where you will be coming from your breaker to supply high voltage to run the motors and compressor. Very easy to do. If it is a heat-pump, you will need to pull at least 8 conductor thermostat wire to wire this up. I would also need to know what terminals and kind of thermostat you have, and if you are using heat strips for second stage of heat. When you say standard unit, you will only need 2 control wires from the indoor to the outdoor unit, along with the high voltage. Please keep me posted and let me know if you need more help on this. A wiring schematic wouldn't be needed if its just a standard condenser.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
1helpful
I have an HVAC with 8 wires, and a new thermostat with 4. How do I identify which wire is what? the blower in the attic states it's a GMC. The only model number I can see says A49-20. It has an external...
Red is 24v from transformer to R onT-stat
Green is from indoor fan at air handler to G on T-stat
Yellow is to compressor for call to cool mode and is Y on T-stat
White is call for heat and is W on T-stat
Orange is to the reversing valve on a heat pump
Blue and or Black are used as common in most cases
1helpful
I tring to change thermosat I can not remeber what color go where
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
How do you wire a honeywell round mechanical thermostat
What are you trying to wire up?
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
I have a coleman Evcon model AH16-0 . I am
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
1helpful
Trying to figure out thermostat wiring diagham on a split system
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Top Heating & Cooling Experts
Paul Carew
john h
