Question about Compaq NX6110 TFT XGA Notebook
Compaq nx6110 My screen no longer goes brighter when I use the power lead rather than the battery. Is there a setting I need to fix.
    Problem Solver:
  • 13 Answers
There are settings in the bios and also on the key board by pressing fn and + brightness
these settings are different for battery and power mode
Posted on Nov 26, 2007
  • 85 Answers
You need to dig around on your machine and find the program the machine came with which controls power usage and adjust the PLUGGED IN versus BATTERY settings; they have gotten reset somehow. Check first in the system tray in the lower right hand corner of the screen.
Good luck...
Posted on Nov 16, 2007
Usually when i plug in the charger to computer the screens gets brighter, it no longer does that, my screen is very dull and not bright how can fix?
you can change that in power settings right click on the battery bottom right of the screen hit change power settings u will get options u want to change power settings look at the options you want to make it stay brite all the time right now you have it set to be brite only when plug is in change the option when its unplugged to brite also
Aug 10, 2012 | Acer Aspire 7741z
I need administrator password for compaq nx6110
1.) Unplug AC, take out the main battery.
2.) Take out /disconnect the RTC (real time clock) battery for app. half an hour (the period of 5 min as specified in the MSG normally is not long enough).
3.) Plug in the AC adapter (batteries still removed); computer should boot automatically, if not use the power button.
4.) The machine will boot and show the 162-error-msg "system options not set". Use F1 to save the settings.
5.) Shut down the computer and disconnect AC power again.
6.) Re-connect the RTC-battery.
7.) Install the battery pack(s).
8.) Restart the computer.
Aug 11, 2011 | HP Compaq nx6110 PC Laptop
Low disk space Error. I have deleted everthing I can and still get thie message, all I want to do is restore it to the factory settings
Do a search on Google for the drivers for your HP Compaq nx6110 PC Notebook. Make sure you have a copy of the 25 digit serial number of your computer handy. Do not do the next few steps unless you have this number. You will need it to reinstall the software to your computer.
Once you have all the drivers (Audio, Video, etc.,) for your HP Compaq nx6110 PC Notebook, you will need an OEM Disk, with Windows XP, Vista or other Operating System on it. Insert the CD in your drive and restart your computer.
Follow the directions that will appear on your screen, as it turns on. Do not let it get past the part where a flashing underscore (upper left-hand screen) goes by, before pressing your space button. You may press any button, but the space bar works great too. You will be given a set of choices to choose from, wether you want to completely reinstall the Operating System, completely Formatting your hard drive, or whether you want to only fix errors. Follow the directions carefully and within 30 minutes to 3 hours, you will have successfully reinstalled the software to your computer.
Nov 15, 2010 | HP Compaq nx6110 Notebook
Compaq nx6110 PC Laptops: When i turn it on the lights flashes then goes off...
Which light flashes? If it is the battery light then perhaps your battery is empty?
When plugged into your PSU does the power light turn on? If not your PSU may have broken or the plugs fuse may have blown.
Other potential causes could be your RAM, CPU or even your system board. Check the RAM is correctly seated, if two modules are installed try removing one.
Hope this helps,
May 17, 2010 | HP Compaq nx6110 PC Laptop
My NX6110 never gets to windows
there is a problem with your bios firmware or nvram. to fix this you can try to reflash your bios, but doing so needs an expertise because if something goes wrong in the process you wont be able to use your laptop again but if still interested just send me a message and ill give you a detailed instruction
Jan 09, 2010 | HP Compaq nx6110 PC Laptop
Unknown hp power-on password
Did you do all these steps in order?
1) Remove the computer power pack battery. Remove the keyboard.
2) Remove the RTC battery. Wait 5 minutes. (I would wait longer, maybe 15 minutes.)
3) Reinstall the RTC battery. Reinstall the keyboard.
4) Plug the AC power into the computer. (DO NOT INSTALL THE POWER PACK BATTERY AT THIS POINT)
5) Turn on the computer.
This should reset the password and also all CMOS settings.
Jan 26, 2009 | HP Compaq nx6110 Notebook
My compaq nx6110 screen goes black and on, why?
This is the issue with the monitor.This is a hardware issue.Please connect the notebook to external monitor and check .If it is working fine then it is the issue with the LCD of notebook If not then this is the issue with the video card.
And ckeck the power cables tooi think this is the issue with the monitor of the notebookAny how you can try to install the latest version of video drivers
Jan 08, 2009 | HP Compaq nx6110 PC Laptop
Won't tune on.
sounds like a motherboard problem if a using a different battery and power adapter did not fix it. Though, you may want to reseat the memory modules, or if available, swap them with known-good memory modules just to isolate that the problem is not memory related.
Dec 21, 2008 | HP Compaq nx6110 PC Laptop
Power On password bypass
Different names, but it is the same thing. I'm not sure if it is possible to flash the bios without that password. I'll look into it. Have you tried contacting Compaq? The guys at the US online support helped me with a discontinued 8 year old model... and I live in Europe
Oct 28, 2008 | HP Compaq nx6110 PC Laptop
Computers & Internet Logo
145 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
