I have been trying to print some documents to my Epson WF-7510. Everytime I do this now, my work queue comes back with a "Error - Printing" and I get a message saying "Communication error". My Epson is connected to my computer through USB.
SOURCE: Epson C43SX communication error
It is presumed the 6 posts in this problem are all from the same person. If one (or more) isn't, and my response below doesn't help, would you you start a new separate post on your particular problem.
A solitary blinking red light means that the ink level in one of your cartridges is low, but printing can continue normally until the ink runs out, at which point the red light becomes permanently on. You must now change the ink cartridge before the print will work again.
If the green light is flashing at the same time as the red one, this means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C43 Service Manual". You will often find them for sale very cheaply on E-Bay. Note, however, if you can find or borrow any of the C40,42,44,60,62 service manuals, as far as ink pad replacement goes, they are the same.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
The reference manual is at
http://support2.epson.net/manuals/english/ij/stylusc43/REF_G/INDEX.HTM
which provides good information on the meanings of the error lights.
Please report back with further information if the above advice doesn't help.
SOURCE: error 306 is happening each time i try to print document.
I reloaded the printer driver and it worked again.
SOURCE: Print queue will not clear after printing
dear sir
this is a typical usb inkjet printer problem
just follow the steps
open notepad
and copy paste
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
and save as delete.bat file on desktop
run this file and reboot the machine
and run this file again
now print queue will get cleared
thanks
SOURCE: document goes to the print queue, then errors
To start with You check the data cable is properly connected to your printer than you open the printer dialogue box and remove the documents pending in the queue and retstart the computer and before giving the print command select the printer that you are going to use(if more printers are connected to the computer).if all this does not work i suggest you to reinstall the printer after uninstalling it
SOURCE: Printer status -- Printer power off Communication error/printer mismatch
Had this exact problem after motherboard smoked and transferred hard disks to a new system. The printer installed fine on a different machine which was comforting, and would be a good test to run.
Turns out deleting the printer isn't enough. Wound up reinstalling the driver. That's a pretty obvious next step but the 1350W driver installer apparently does things its own way so if the windows add new hardware wizard comes up you MUST cancel it. Not sure which of these steps are required and which are not, but here's what I did to the best of my recollection ;-)
0) Turn off the printer.
1) Delete the printer (all instances of 1350W) in printers and faxes.
2) In add/remove programs delete the Konica Minolta application.
3) Reboot (this was always a key step in Win98 reality, not sure if XP requires but it can't hurt.)
4) Turn on the printer. If at any time the add new hardware wizard comes up, just say no.
5) Run setup from the driver CD. If you don't have the CD you can get it from KonicaMinolta or CNET (download.com).
6) For me it defaulted to LPT1 but I chose USB001 from the list.
7) If it throws an "error adding service" message don't panic. That may be why there was a problem to begin with (the error, not necessarily the panic.) This happened to me but clicked OK and after several seconds the installer resumed. Next thing I knew was prompting me to add paper.
The error message (for Googling purposes) was:
Error Adding Service
File: MLPTDR_Q.SYS
Dependencies: +Parallel arbitrator
Load Order Group: Extended base
dwServiceType: 1
dwStartType: 2
Hope this makes someone's day.
DaveWasHere
