There is usually a schematic pasted to the inside service area unless it fell out. Read it & start tracing wires. The power to the element should pass through a fuse, a thermistor(cycles power on and off relative to heat and a safety switch that kills power if it gets too hot. Don't take short cuts.
SOURCE: Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
SOURCE: Is there a wiring diagram for installing the
You can try here....http://www.partselect.ca/default.aspx
Or here: http://laundry.manualsonline.com/manuals/device/clothes_dryer.html...?
Hope this helps...
SOURCE: replace electric heat element in Amana dryer
You can find an exploded view of the dryer on searspartsdirect.com. Looks like you access from the rear service panel.
SOURCE: My Amana dryer LEA30AW makes a loud knocking noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fo
