Most LCD tv's built in the last 4 years are HD compatible. Most cheaper brands tv's are 720 HD and some are full HD 1080 a little more money. Since their is no more analog broadcast as June 2009 all tv's manufactured around 2006 started incorperating the digital tuner (DTV) along with the analog so that the tv would still receive analog broadcast while the digital transistion was ongoing. All tv's with a Cathode Ray Tube (glass picture tube) are not HD compatible. First you will have 1 or 2 ports on the tv ethier on the side panel or rear panel of the set. They a marked HDMI 1 HDMI 2 or HDMI A HDMI B. If you have these ports your set is Hd Compatible. You may also need to upgrade your cable or satelllite equipment and subscribe to a HD package to be able to get HD service. You will need a HDMI cable to connect your cable or satellite receiver to the HDMI port on you tv. Call your local cable or satellite provider for options to upgrade to HD. Most over the air broadcast stations depending on your area transmit some stations in HD free of charge. A good quality outdoor antenna works best to give you stable signal. You may need to change the settings of the tv as some sets default to the 480i this is the standard digital signal.
You can get 720p or 1080i " fake 1080 " through the RGB component inputs, But you will not get 1080p true 1080 res. But, this TV is only 720p anyway. But,it will still make a big difference in the pict. up-grading. And having the new HD box when you get new your new service now,will save you $100 from needing to buy a HD box later if you have a new TV with the HDMI. As DirecTV will give you the HD boxes free with new service. But,charge later if you have up-grade from a standard box. No sure how Dish network does tho. But, not have had too many customers happy with Dish. DirecTV is the way to go. And the signal during the rain is so much more problem free.
Call Dish back. Your HD signal has to be configured in your dish receiver. They can configure it for you over the phone. If not, then the dish guy has to adjust the wires at the splice box wherever it's located in your house. HD requires a dual cable line from the dish to the splice block. It's not the TV.
Your HDTV is capable of up to 1080P resolution. SDTV (standard def) signals are 480i; EDTV (enhanced def) is 480P; HDTV are 720P, (there is no 720i) 1080i and 1080P. Generally, those modes ending in "P" look better than those ending in "i". 1080i is the highest possible for broadcast TV, but BluRay disks and Directv have 1080P display capabilities.
The double picture you're describing sounds like the TV is set to display only standard or enhanced def signals while the Dish Network box is supplying it with HD signals. You should locate the control for the TV's resolution and make sure it is set to "1080P" and then set the output of your Dish Network set top box to the highest output it offers. Do the same for your BluRay player and any other devices, too.
Once set correctly, you should have a great picture once again. I hope this helps & good luck!
Hello, this is Nick Franta with DISH Network Customer Support.
You can still keep the 322 receiver with your new LCD tv. An HD receiver upgrade would be beneifical as well to make sure you maintain the best picture quality.
have you tryed to go to setting and letting it yout tv know that you want sound onto the hd channels.? if you have any more problems joust contact you coustmer service for dish network. problalby your tv is not compatible and you need an hd receiver. i have dish network myself and just upgraded my receive to hd.
Closed caption is an extra for the TV tuner you have it may not be on the set for HD ie: your set is now recieveing it's picture from the cable box and not your TV tuner probab;y by scart or SVHS cable , and the equipment you have may not have Closed Caption capability check with your network supplier ..... Regards Vortash
PS will it work if you go back to normal tv I think it might .? and if it does case proved ..
Which network? Cable? Satellite? Dish or Direct?
With any of these providers, you should get an ATSC or "digital" signal. If not, the problem would most likely be with the service provider since they are converting the signal for you. The only way that your set would be affected is if you have an "off air" (antenna) signal only. At this point you would need a converter box. If your service provider is providing you with a HD receiver, then you should have no problem recieving HD (as long as your paying for HD). However, keep in mind, digital is NOT HD. If there is an incompatability with your receiver, check with your service provider for a software or hardware upgrade. Also, check with your local TV serviceman to find out if there are any software upgrades (firmware) for your TV. Being three or so years old, it is possible.
One last thing to check is to see what type of signal you are passing from your providers box to your TV (which type of cable". At a minimum, you need a "component" connection to pass HD content. A "composite" signal is standard definition. Best you can get right now is an HDMI cable. Best "one cable" source for video and audio.
Good Luck.
Tim
Certified TV
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
if the tv has the red... blue...green ..picture inputs you hook in through there and you dont have to do anything because your cable sat box will seng the HD signal right through to your tv!
