Need to make sure both fans are working and the compressors is running all the time the fans are. If not we need to check the compressor for overheating and look behind back panel in freezer for frost build up. Let me know if you want my help, Sea Breeze
Unplug first.
You are doing good getting your message on line. Your refrigerator side should be getting 39 to 42 degrees by now and the refrigerator should defrost every 10 hours. If not I will need you to to check the timer inside the fresh food section. There will be a small opening through the plastic control panel with a small round hole possibly plugged with a piece of plastic to hide the opening. Remove the pulg and with a flathead screwdriver turn slowly clockwise until the refrigerator stops. It should remain stopped for about 25 minuits. If it should not turn itself back on then turn timer again clockwise until it starts. For now just let me know how things are doing and get back with me, your defrost timer part number is 482493 Thank You for rating me!
Thanks Sea Breeze
SITE=>http://servicepartstec.blogspot.com/
SITE=> http://appliancepartseast.blogspot.com/
Dan, Just checking back with you. Did we get the refrigerator fixed or do you need more help? Sea Breeze
[email protected]
Check that you hear the freezer fan blowing .
Hello H,and thanks for the reply. It's been a few hours since it's been on,but we haven't put any food in, yet. The freezer is excellent,and we even turned it down,as it made ice cubes quick. There is some frost building in the the center of rear wall,though,although just noticeable in fingernails. The fridge has a bottle of soda in it,and is not yet cold,so I think I have a problem. It is not setting any records getting cold,that's for sure. I thought maybe since the freezer was so good,it would be O.K.? Thanks,Dan
Hello, Thanks for reply. I am new to this site,and didn't think my questions made it on, but I'm glad to see they did. Both fans are running, and compressor is working,at same time. Freezer is excellent,after a few hours of being plugged in, and made ice fast. Soda in lower fridge has a way to go, yet, and sure isn't quick. I will check back in the morning. Thanks very much,Dan
It sounds like the cooling coil is freezing-up. I had a similar situation. Does the rear wall of the freezer and/or the floor of the freezer have a buildup of ice or frost?
