Question about Lite On LVC-9016G DVD Recorder/VCR
Invalid disk error
Updated firmware
  • luvtojump Apr 18, 2008
    I have updated the firmware but still continue to get invalid disk disk error. Have tried several different brands of DVD's to no avail. Seems only to recognize old previously very worn used DVD's w/4x speed. Is speed an issue? Can't even buy that slow of a DVD anymore. Thanks for any help out there!
    Problem Solver:
  • 13 Answers
I had a problem with a Lite-On Lite-On that had been working fine then stopped reading any disc--sometimes it would go through the motions of recording if a disc was in and a timed recording was due to start. After recording it would not read the disc. A google search led me to find the a dirty laser would cause this. I removed the cover and with a clean lint free cloth I used rubbing alcohol to clean it and it has worked fine since. While I had the cover off I took the unit to my garage and used an air compressor to blow all the dust out of the unit and cleaned the laser again just in case. That was about 6 weeks ago and it works fine. My unit has a cooling fan that I think contributed to the dust problem.
Posted on May 19, 2008
INVALID SCANNER CODE error
You need to download the firmware from support.lexmark.com then send it to the printer either via the network connection or usb. If you are connected by ethernet you can put the devices IP address into internet explorer and send it via the printers built in webpage, you will find an update firmware option there in the configuration menu. To use usb you would need to get the usb flash utility first
Jan 21, 2013 | Lexmarkr X646E Multifunction Printer -...
"system timeout" lexmark
The frimware update cannot see the printer because the printer is in error state. You need to clear the error by disregarding the error. To do this, you to make the error invalid. Please follow the steps below:
1. Turn off the printer.
2. Press and hold the the "back" and the "left" arrow button, and then turn the printer on.
3. When the printer displays "Invalid Engine Code", update the firmware of the printer.
Dec 05, 2012 | Lexmark X543dn Laser Color All-In-One...
49, 4c02 error in hp 4250
This is what the result for that error code is:-
ERROR 49.XXXX
A critical firmware error has occurred that caused the processor on the formatter to abort the operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some instances, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or specific software programs. Remove all EIO devices and firmware DIMM if installed. Restart printer. If error is gone replace each EIO device until error appears. Replace device which triggers error. May also be formatter.
Firmware updates are available for some machines at http://hp.com and clicking on the drivers and software tab. Also try printing from a different application. If that works go back to the first application and try printing a different file to determine if the problem is file related. You may need to reseat the memory DIMM's or replace the firmware DIMM or formatter board.
Feb 08, 2011 | HP LaserJet 4250dtn Printer
My samsung BD-P2500 Bluray player is stuck at a load message
Hi.
First try disconnecting power cord for five minutes. On restart keep playing eject while the unit is starting up, to eject if there is a disk stuck inside.
Contact Samsung support number, listed on the owners manual. If a firmware update is available they will guide through the update.
If the firmware update does not fix the problem, then the BD player may have a defective or dirty lens.
Using lens cleaner can invalidate warranty, talk to Samsung first.
Dec 14, 2009 | Samsung BD-P2500 Blu-Ray Player
Error 49.420c
first try to upgrade the firmware
second try a cold reset
if this dont work change the formatter
Aug 06, 2008 | HP LaserJet P3005 Printer
Sony DRU-710A doesn't write others than DVD+RW anymore
I updated the latest firmware provided by sony and could solve the problem.
Regards
Hannesfx
Feb 10, 2008 | Sony DRU-710A DVD±RW Dual Layer...
Invalid disk error
Did you get this working? If not, then your DVD isn't supposed to be region free in the first place, and I can send you a firmware which I have used a hack in order to make region free. You can then take this firmware and follow the same instructions you used for the other firmware.
Jan 07, 2008 | Lite On LVC-9016G DVD Recorder/VCR
Printer HP Laser Jet 7400
99 % of time it is a corrupt file or poor connection, I have also known it to be the firmware, dimm or formatter board on rare occasions.
Recommend check hp web for any firmware updates, check connections and that driver is installed impecablly and use known good files to test.
Dec 27, 2007 | HP LaserJet 4500 Printer
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
Lite On LVC-9016G DVD Recorder/VCR Logo
421 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
