Question about Philips Cineos HTS9800W System
Hdmi my cineos wont play hd dvds my tv is hd ready i have a hdmi cable connected
Re: hdmi
I have just purchased a Philips DVD Home Theatre System HTS8100 (Soundbar), HDMI, ambisound, etc. When I play some DVD's though I get the message "wrong region". What does that mean and how do I solve it. Also why do only some DVD's come up with that message.
Posted on Feb 05, 2008
Re: hdmi
Its not designed to play HD DVDs, the model has HDMI connection in order to connect to latest output devices, viz flats panels and LCD tvs there by having a common audio and video cable. your model has a feature to upscale the normal DVD singal to match the quality output of hull HD TVs, hence the HDMI out put, do not confuse this with HD compatiability.
Go to the link below to check the full specs of your system.
though yours is a high end set, but its not HD disc compatiable.
Posted on Dec 04, 2007
0 characters
3 Points
Sony flat-screen bravia tv picture goes black but keeps playing audio when playing Netflix or DVDs.
your dvd player needs its own connection as does netflix and cable,get a new hdmi cable for each
Jul 11, 2015 | Samsung Home Theater Systems
I have an older onkyo 1994 or 1995 receiver dolby pro logic with the amplifier and 6 disk changer wnd the system is clear as could be in cd mode. my problem is Ihave my xbox hooked up to the tv with hdmi...
No no no!
# 1. You need to connect all your components to your TV via an HDMI cable. For true HD and digital sound this is needed. Your TV (if its an HD TV) should have 3 or 4 HDMI inputs. So your Xbox/PS3 should be connected via HDMI cable. Your HD sat or cable box should also be connected with an HDMI cable. Same for your Blu Ray player.
#2. Now that your components are connect in a way which will enable you to see their media in either 720p, 1080i or 1080p your ready to get the Digital sound to your speakers. On the back of your TV you should (again on most all HD tv's) have a digital audio (optical) out. You need to purchase a digital (optical) audio cable and plug one end into your tv's digital audio out jack. Then plug the other end into your audio receivers digital audio in jack. You may have to go into your receivers menu to select or enable the digital/optical input. Then you should be rocking and rolling with true digital DTS, Pro Logic, Pro Logic 2 in either 5.1 or 7.1...
Think of your TV as the hub. Connect all the components with HDMI cables. And then your TV to your receiver with a digital/optical cable. It's that simple.
Never never use the red and white cables for audio. They were designed for 2 channel stereo sound. They won't deliver 5.1 or 7.1 digital sound.
Also... Don't ever hook up any component using the old "yellow" video cable if you want picture quality better than 480i resolution. They won't do HD period.
Here is a list of the popular video cables and they highest resolution.
Yellow video cables - 480i resolution
S video (super video) cable - 480p
Component video cables (red/blue/green) - up to 720p
HIgh definition multimedia interface HDMI - up to 1080p (full HD) and digital sound.
Hope this helps...
Nov 03, 2012 | Onkyo Home Theater Systems
How do i hookup my magnavox mrd 210 to my lcd tv for surround sound. have tried to connect with rca wires in back of tv to surround sound system and nothing. tried side of tv and nothing. my surround sound...
Have you seen the user guide?
The TV is intended to be an end point of the video, not a source of audio. Many TV's (monitors) don't have ANY audio, much less surround sound capability. Composite Video is theminimalist video connection for setup; Component video to the TV should suffice for viewing DVD's.
Is your TV the SOURCE of surround sound programming (via an antenna) or does the programming come from elsewhere like a Cable Box? THAT would be the source you need to tap for surround sound.
Aug 23, 2011 | Philips Magnavox MRD210 System
How do i use it so my tv programming is in surround sound?
if the Comcast cable box has an HDMI output, it should connect directly to one of the TV HDMI inputs. Then connect the LG DVD unit HDMI output to the second HDMI input of the TV. Use two HDMI cables. Do not buy the expensive Monster HDMI cables. If you have already done so, I recommend you take it back for a refund, then buy the low cost HDMI cables which will work just as good and then you can bank the savings toward a new Porsche Boxter!! Now we have the video connected from both the cable box and the LG system.
Now--what do you do if the cable box does not have an HDMI output--just use its component output and your component cable (red, blue and green) to connect to the TV component input. This will still get the video to the TV and good HD pictures. Hum--do you have an HD cable box? You did not say and I just assumed that you did since you got the HDTV. If not, let me know with a follow up question and I will assist in that area further.
Now for the audio connections--The DVD player will not need any connections since it in the LG unit. The sound will come out the speakers when you start playing the DVD. The cable box is where we get the TV audio to feed the LG unit. If the cable box has an optical output, use an optical cable (again the low cost one)and connect to the optical input on the LG.
This will get the TV audio to the surround system. If no optical output, use the red and white (left/right) audio connections and connect to one of the two the LG audio inputs. To hear TV audio on the LG speakers, just switch to that input or the input associated with the optical input.
To watch DVDs, switch the TV to the HDMI input to which you connected the LG unit. For TV, go to the other HDMI input (or component input).
Switch the LG to the audio input to which you connected the cable box to get TV sound.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Sep 11, 2009 | Home Theater Systems
Connect lifestyle 48 to plasma and dvr
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
Sep 10, 2009 | Bose Lifestyle 48 System
Audi but no picture when cable box conected through DAV-X1
It won't work as the DAv can only output to HDMI by bringing singal into the HDMI input.
why wouldn't you send it directly to the TV and Audio to the DAV? I sounds like you don't have an HD box anyway (otherwise why would you use an analogue S-video cable vs component or HDMI). Unless there is a distance issue then go to the TV.
Dec 25, 2007 | Sony DAV-X1 System
Panasonic HDMI surround system problem
The HDMI cable connection on your system is a video out to your TV.
To get audio from the TV so you can hear it through the system, you need to add a cable from the audio out of your TV to the "aux" input on the panasonic system.
This is most likely a red and white connection which will give you stereo, or pro-logic surround from the home theater system.
Dec 23, 2007 | Home Theater Systems
Tv sound on home theater kit
Hi Every one.
Had same problem with my HDMI connection on my sony bravia and sony theatre system, resolved by conecting a scart lead from the theatre system to one of the free scart sockets on the back of the TV, leave your HDMI connection in place as the DVD signal comes from this,
hope this helps!
Dec 20, 2007 | Home Theater Systems
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Philips Cineos HTS9800W System Logo
416 people viewed this question
Top Philips Home Theater Systems Experts
Gyula Lacz
Are you a Philips Home Theater System Expert? Answer questions, earn points and help others
