Question about Car Audio & Video
What causes 2003 bmw x-5 radio for radio not to work but the speakers sound like they are popping
I had 2003 BMW X5 brakes worked on now MID and radio do not work but the speakers are popping... What is causing that
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 73 Answers
First check to see if one of the positive wirs is touching your ground wire
Posted on Jun 05, 2015
2 Suggested Answers
  • 4889 Answers
SOURCE: my radio in my 2001
Have you had the battery disconnected recently?
If so then your radio may require a code
Posted on Apr 24, 2011
BMW x5 2003 fuse box location for rear wiper
It is in the Glove box. there is a drop down panel in there on top with 2 pins that holds it in.
Oct 14, 2012 | 2003 BMW 5 Series
2001 BMW X5 radio works intermittently
Most sat nav/radio issues are caused by a flat battery! The most simple solution to try is th switch the vehicle off, go to the fuse box on the right hand panel of the boot (as your facing boot) remove fuse 24 (5 amp) for 5 minutes then replace and start vehicle as normal! This will reset the nav/stereo system! Rich B
Apr 07, 2012 | 2005 BMW X5
I recently had my 2003 bmw x5 jumped due to dead battery from leaving my lights on. since then i cannot get sound to come out of my speakers. radio is on but now sound. please help.
Try disconnecting the battery for 10 min and see if resetting the system fixes your problem . You will loose all your presets but you can reset them, if it works Good Luck
Mar 02, 2011 | 2005 BMW X5
Stereo on a 2004 bmw x5 works but no sound from speakers
hi, there is no sound coming through my speakers in my car how do i solve this problem?
Sep 04, 2010 | 2001 BMW 5 Series
The brake lights are not working and i already
Have the brake switch replaced or checked out. This is what turns your brake lights on when your press the brake pedal.
Jan 11, 2010 | 2003 BMW 5 Series
Just had the battery replaced. The 2001 BMW X5 brake and abs lights are on. Is this a Battery problem, fuse or what?
This sounds like a low-brake-fluid-pressure symptom. Check brake fluid. Next check for leaks.
More info?, let me know...
May 08, 2009 | 2001 BMW 5 Series
2003 BMW X5 radio display lights
BMW has a free fix for that! It's a factory recall with the pixels. Check with your dealer.
Oct 21, 2008 | 2005 BMW X5
How to replace rear break bulb on BMW X5 2003?
1st verify that the brake lights work, if not replace the burnt bulb, if they are ok then the warning module is defective.
Aug 18, 2008 | 2003 BMW 5 Series
Radio has no sound
Hello, I've the same problem... however my sound is likely there when I restart the X5 after an hour or so, but it is as likely to disappear during the minutes that follow, often when the car is shaken.
There is then a fair chance to get sound back as soon I drop the phone after a phone call (but it does not always work).
--> My guess is that it is the line of the Phone "mute" signal that brings every sound source down thru a bad contact or so.
BMW wanted to replace the radio for 900 €. Hmm a lot of money for a bad conatct if my guess is right.
Gary
Jun 14, 2008 | 2001 BMW 5 Series
Car Audio & Video Logo
746 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
