Question about Whirlpool GEW9250 Electric Dryer
Door sensor I need to change the button that lets the dryer know that the door is closed. i already have the part but not sure how to get to it in the dryer.
    Sergeant:
    Champion:
  • 262 Answers
POP THE TOP FROM THE REAR WITH THREE SCREWS FROM THE FRONT KINDA POP THE TOP BACKWARDS ON BOTH SIDES WITH YOUR HANDS.REMOVE TOP PANEL AND YOUR IN THE TOP
THE BOTTOM REMOVES WITH THREE SCREWS UNDER THE BOTTOM PANEL REMOVE THESE AND PUSH DOWN AND OUT AT THE SAME TIME AND YOUR IN THE BOTTOM CHANCES ARE YOU CAN GET TO THE SWITCH FROM THE TOP
Posted on Dec 16, 2007
THE LIGHT WILL NOT COME ON WHEN THE DOOR IS OPENED AND THE DRYER WILL NOT STOP WITH THE DOOR OPEN
The dryer has a switch in the door that is activated when the door is opened/closed, replace this switch or check the connector to it or the wiring.
Oct 25, 2016 | Kenmore Dryers
Close front door message when front door is already closed
I am having the same problem... did you manage to resolve it? Let me know
May 16, 2013 | Saeco Xelsis Digital ID Automatic Espresso...
Dryer wont stay running
Without the make and model number of the dryer, this is pretty hard to diagnose.
It could be relays, the main motor, or even the circuit board if it is a modern fancy electronic dryer.
Mar 10, 2013 | Dryers
Our dryer won't start. The door is properly closed and no indicator lamps are on. The dryer is only 5 years old and has been maintained according to the companys instructions.
I think the circuit's logic is waiting for some sensor to respond. If possible try opening the case and look for some loose wire connections. Usually the sensors will at door closing - if door is already closed properly and still this happens then try bypassing the sensor by cutting down the two wires connecting to the sensor and joining them (two wires) together.
Oct 18, 2012 | Dryers
My garage door is not closing. I have to use the wall switch to close it. I dont see any light on the sensors. Please let me know.
Do you have little eyes on your walls or track on the or near the bottom of your door. If so make sure they are both green and if there not theres something in the way. I need to know more about your problem to help you. it could be your down pressure button needs to be turned up it's on the back of the operator 2 blue buttons numbered 1 to 10 turn that up may fix your problem. please let me know there are a few other things that can do this
Apr 09, 2009 | liftmaster Chamberlain Garage Door Opener...
Help
most of the time it is the door switch that goes bad or the main fuse on the blower box inside fails,you can also check to make sure the dryer wall vent hole or dryer hole is free and clear,let me know what you find-mike
Oct 29, 2008 | Kenmore 63942 Dryer
MY MAYTAG DRYER DOES NOT WORK WHEN I TRY TO START IT. THE LIGHT TURNS ON WHEN I OPEN THE DOOR HOWEVER. THE DRYER IS 4 YEARS OLD.
try this first:
  • turn off the dryer circuit breaker in the house then turn it back on. sometimes the dual breaker will trip on only one side leaving you with a non functioning machine that seems to have power.
  • also check the door switch and make sure it is clicking when you slowly close the door.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Aug 04, 2008 | Maytag Dryers
Dryer door pops open after running 5 minutes,close door hit start button door opens.let set 10 minutes ,run 5 minutes door pops open .dryer not overloaded. Serial #GEQ8811KTO
door strike is bad also door may be warped make sure door is not warped if it is just twist in opposite direction if strike needed part #279570
Jun 14, 2008 | Whirlpool Dryers
Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
Dec 23, 2007 | Kenmore 63942 Dryer
Whirlpool GEW9250 Electric Dryer Logo
57 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
