Vacuums Logo
Tom Sadler Posted on May 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a diagram of how to put the roller brushes and belts back together
John Mock
Level 3:
  • Vacuums Master 932 Answers
  • Posted on May 17, 2015
John Mock
Vacuums Master
Level 3:
Answers
932
Questions
Helped
273686
Points
5591
Tom,
What model Bissel?
5 Related Answers
Anonymous
  • 625 Answers
  • Posted on Sep 15, 2007
SOURCE: hoover windtunnel U6439900
please go to the hoover vac store using the following link. you will have your exploded diagram for the machine and any spare parts you might need. http://www.thehooverstore.com/U6425.html
b0sslady2001
Marci Marple
  • 357 Answers
  • Posted on Nov 09, 2007
SOURCE: Vacuum brush roller with belt attached is off
Here is a very clear online instruction guide for the shampooer. Hope this helps!
Marci
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Anonymous
  • Posted on Jun 04, 2009
SOURCE: brush roller on windtunnel won't spin
It sounds like you need to replace the actuator arm or the cable to it. Look for Hoover part 43143046 for a start. I've got a similar problem.
Anonymous
  • 3600 Answers
  • Posted on Jun 19, 2009
SOURCE: LittleGreen Machine Pro turbo brush put back together
here is the web site with the parts breakdown.
http://www.marbeck.com/carpetcleaner_parts_bissell.html
Anonymous
  • 3 Answers
  • Posted on Aug 03, 2009
SOURCE: roller brush doesn't turn
Sometimes you have to replace the brush roll itself depending on what kind of vacuum you have.
I got a shoelace caught in the roller brush on a vax upright pet and the brush has now stoped spinning. How do I fix this please?
your gonna need to remove bottom plate and take a sharp knife or scissors and cut the string close to the brush then peal off. might need to replace belt at this time. just pull out brush roll and remove belt then match it up with new one and put it back together,
Jan 29, 2013 • Vacuums
When we changed the belt the new belt broke right away and the brush roller wouldn't spin. My husband cleaned off the roller and got it moving slowly again, but when we went to re-attach everythin
the thing you call wheels are actually called roller bearings that fit at both ends of the brush-roll there probably seized up you can get a new brush-roll with bearings from the link below.
http://dirtdevil.com/parts/category/brushrolls-uprights/
1helpful
Brush doesn't move
Your belt is broken and needs to be replaced. Turn this brush side up. Unscrew the cover plate and you will see where the belt goes. Pull out roller, put on new belt, put back together and there you go.
5helpful
How to change belt on eureka whirlwind; what tool do I need
You will first need to remove the hood to gain access to the belt and brush roller. Turn the machine upside down, place the handle on the floor and the base on a counter. You will find several screws that hold on the hood, remove them. Turn the machine back to the upright position and remove the hood. On the right hand side,if your looking the front you will find where the belt goes. At the back you will find a silver shaft sticking out, put the new belt on there first. Then put the brush roller through the belt so it is in the carved out section of the brush roller. Then grab the brush roller by each end and stretch the belt till the brush roller fits back into the base. Turn the brush roller 3 compleat turns backwards and 3 forward to seat the belt in the proper position.
Then put back on the hood.
6helpful
How to put the belt on the deit devil breeze
Here is a detailed discription on how to change your belt. Turn the machine compleatly upside down and place head on a flat surface. There are 4 screws to take out, then remove the base plate. Near the back of the channel the belt rides in you will see a stright silver shaft. Place the new belt over that shaft. The put the brush roller through the belt, so the belt is in the notched out section of the brush roller. Grab both ends of the brush roller and pull till the brush roller is back in it's origial spot on the base of the vacuum. Turn the brush roller 3 compleat turns backwards, then do the same forward to seat the belt. Put back on the base plate and put back the 4 screws. You are now ready to vacuum.
Change belt on model 6850 bissell
Turn your vacuum over and remove 6 screws holding down the cover plate which has the roller brush under it. Remove cover plate and pull up on brush. Belt will come off with the brush. Put back together in reverse order with new belt.
Jun 29, 2009 • Vacuums
3helpful
2answers
Bissell proheat turbo 2x upright cleaner -how do I reassmeble?
Yeah, it’s annoying that the manual doesn’t give more detailed instructions and drawings to help with this, because you do have to take the roller assembly apart sometimes to clean built-up carpet lint off the unit properly. If you don’t do this, I’d expect you’d have more problems.
I have a different model number Bissell Proheat than yours. Yours may have different parts or go together differently than mine, but I'll tell you how I do it on mine and you can try my way out and see if it helps you.
(In all cases where I use left vs. right or front vs. back, as when these terms are used with a car, I am facing the front of the Bissell. I am NOT behind the Bissell, where I would stand when cleaning carpet with it.)
Here's how I put it together. This takes much longer to describe than to do, once you figure out where everything goes and you get the hang of doing it!
Attach the left arm with the two silver rods (ONLY attach the left arm here-- leave the corresponding right arm, which looks like the left arm except it has no silver rods, off the bottom unit of the Bissell, for now) to the left side of the Bissell, with a silver screw with a built-in washer. The screw hole is on the back end of the arm and the arm dips down towards the front of the Bissell and holds the two brushes in position so that they can turn without striking the top of the underside of the Bissell or dragging on the floor.
Put a small silver washer on each long, silver metal post, where the roller brushes will go, and slide it all the way to the left.
Put the larger rubber belt around both metal posts, about halfway to two-thirds of the way down the metal posts.
Slide the brushes halfway down the metal posts and attach the larger rubber belt to the cog wheel on the left side of each roller brush. Then slide both roller brushes with the large rubber belt attached all the way to the left so that the cog wheels are against the inside of the left arm. As you move the roller brushes almost all the way to the left, you may be blocked from reaching the end until you carefully work the rubber belt around a plastic flange on the inside of the left arm, but do this and be sure the roller brushes are up against the inside of the left arm. Make sure the rubber belt is still on each of the cog wheels when the roller brushes are pushed all the way left. If you turn one roller brush, the other should turn, too, because of the belt attached to both cog wheels.
Put the small belt around the small cog wheel on the bottom unit of the Bissell behind the right end of the back roller brush, and also around the cog wheel on the right end of the back roller brush. (The right cog wheel on the front roller brush is the only one of five cog wheels without a belt, when everything is assembled correctly.)
Put a small silver washer on the right end of the silver rod passing through the back roller brush.
NOW attach the right arm, using a silver screw with a washer, to the middle screw hole on the right side of the bottom unit of the Bissell. The right arm should mirror the left arm, so that the two arms hold both roller brushes in position on the right side and straight across the bottom unit of the Bissell. It is normal for the roller brushes and arms to be able to flex up and down a bit, when everything is put together correctly. The built-in washers on the silver screws which attach the arms keep the arms and roller brushes in the generally correct position but allow them to flex.
Now using your fingers you should be able to slowly spin the roller brushes without the brushes contacting the top of the bottom unit of the Bissell and without dragging too low against the floor. Check one more time and be sure the belts are positioned correctly around four of the five cog wheels.
If everything seems right, attach the two side covers. These are not interchangeable; the left cover only fits on the left. The short black screw goes in the back screw hole, and the long black screw goes in front.
Then attach the front cover. It's important to be careful that the hooks on the front cover are inside the side cover holes designed to hold the hooks before trying to tighten the last screw through the tab on top of the front cover. If you aren't careful about this, it's easy for the front cover to be out of position or to break its tab.
Try powering up the Bissell and see if the rollers spin correctly. Remember that the handle must not be locked upright and the trigger must be depressed with the Bissell turned on before the roller brushes will spin. (Sometimes people complain that nothing happens with the unit turned on and the trigger depressed when the only problem is that the handle is in the locked upright position.)
Replacing brush roller on my KIrby g6 limited edition
You need a new belt. When the green light goes out, that means your brushroll has stopped spinning. Here's how to change it....
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Even if you just replaced the belt, this guide will help you make sure that you got the brushroll back in the right way.
Hope it helps....
Marci
Hoover Wind Tunnel
what probably happened is you swapped end over end when you replaced the beater brush. anyway go to thehooverstore, find your machine and you'll see an exloded diagram of your machine.
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
