Refer the user manual for both; to get more wiring details. Gopakumar Gopalan Google
SOURCE: I have a Samsung hw c-451 sound bar.I have it
Dish doesn't appear to have a code for Samsung receivers but try the Sharp codes listed. Here's a link
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml#amp
Same thing for the LG remote
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3252
I recommend connecting your sound bar to your dish receiver as well as to the television. Play around with optical and RCA to see which one you prefer the sound of. The television isn't always the best center channel so you might find that you like this set up better with the dish receiver connected directly to the sound bar. Then you can shut of the television speakers. Some people turn the television speakers back on and leave the sound bar off for early morning breakfast news viewing. Not being sure which dish receiver you're using you might have to indicate to it how you wish to output your audio, or all outputs might be outputting at the same time all of the time.
SOURCE: LG sound bar connected to Pioneer TV by optical cable not working
1. if you have something else that you can test the optical wire on. do that first. dvd player etc... if the test item works, it's the sound bar (or a setting in the sound bar.)
2. check the audio settings on your t.v. make sure it's set to output to optical.
3. replace the wire.
if none of these solve the problem, the t.v.'s optical output may be bad.
