Question about RCA HD52W59 HDTV Projection Television
Language Selection Every time I turn on the TV it comes on to the blue language selection screen. I have tried all of the setup options and none work. It will go to the channel and I can here the sound but I have to select the language and hit clear or enter every time I turn on the TV. Also, when I use a timer, for when we are on vacation, it also comes on to this language selection screen when on the auto on mode is activated. JJS
I had that happen. I found out that I had the VCR turned on. So I turned that off and The language select went away.
I was connected from satellite to VCR then TV.
Posted on Dec 24, 2007
Need to know how to change language to English
Changing the language of your choice is not a great deal. Check the instructions provided below and know how to change the language to English.
-> Power off your printer, keep the printer setup undisturbed for a while, and then power it on.
-> Get directed to the control panel of your printer, slide the display to the left, and then click on the settings icon.
-> Tap on the first option ( Preference menu )that screens on the control panel.
-> Click on the Language option. Liable to the printer model, the language selection option comes in first or second in printer's control panel list.
-> By doing this, the list of available languages will be displayed on the screen.
-> Scroll through the entire list and choose English ( as you wish) and then click on the Yes option.
[link 1]
123 hp com Quick HP Printers Setup Easy Installation Guidelines
Dec 28, 2015 | HP Officejet 6500 Wireless All-in-One...
My toshiba tv is stuck on initial setup menu, language selection. original remote is not working
Hi,, today i got the solution for the problem 'Tv Stuck On Language Screen"
I have Skyworth Lcd and it was stuck on Language screen 4 days back, i've tried every sigle App and Different Universal Remotes and buttons on Tv but nothing was working except a single App named "SURE UNIVERSAL REMOTE FOR TV"
i suggest if someone face this Language screen stucking problem and no buttons and remotes are working then you should download this App on your Cell phone and select your tv and you'll surely be able to restore your Tv.
Feb 10, 2013 | Toshiba 40RV525U 40 in. LCD TV
Ilo tv in spanish need english
To change the menu language of the TV using the remote:
Display the menu screen.
• Press [MENU].
6 menu items will be displayed. The third item will be ENG/ESP/FRA
Select "ENG/ESP/FRA".
• Using [CH up / CH down] buttons, select "[ENG]/ESP/FRA".
Every time you press [VOL up / VOL down] buttons, the language
will be advance to the next. Select the language. When ENG is selected, exit by pressing [MENU]
If you are trying to change the AUDIO of the TV, simply press the [AUDIO] button on the remote. This will advance the selection between MAIN, SAP and MONO. MAIN is the native language of the program (often in stereo), SAP is "secondary audio program" - which is usually a second language, but may be an audio source not related to the picture at all. MONO is monophonic, or a single sound source that is the result of combining the LEFT and RIGHT stereo channels to one output or speaker. This selection is often a downgraded version of the stereo output provided by the MAIN audio selection - but may be useful under certain conditions.
You can review your manual here. Pg. 31 has details for the menu display language selection and pg. 16 has details for audio language selection.
If you found my answer to be helpful, please rate it "very helpful" Thanks & good luck!
Aug 22, 2011 | iLO IWT3206 TV
How to get subtitles in english .they are coming in another language
To select the language, do the following.
[1] Press Menu and the press Left or Right arrow on the remote to select language option.
Choice of language selection [3] will appear on the screen.
English, Espanol and Francias
[2] Press Up or Down arrow to select the desired lannguage you want to be displayed on the screen. Then press ENTER.
[3] Press Menu repeatedly to exit the Menu screen to be cleared.
Jan 11, 2011 | Toshiba MD20F51 20 in. TV/DVD Combo
My remote no longer works and I can't get the menu to come up so that I can reprogram my channels and get all of my cable channels. Right now I only get basic cable channels, even though I have full...
You will have to disconnect the TV from the AC outlet for a few seconds(10-20) then reconnect the TV and press power. You should get the start up menu after you get a picture. What you have to do is use the vol up/dn , chnl up/dn keys to select the autoprogram setting after chosing from cable or antenna signal. the enter key should be one of the DVD keys either play or stop or some other key, you'll have to experiment a little with it. There is an owners manual available at in case you need it, but I am posting a brief description stated in the manual on how to do this. Chapter Summary: The STARTING SETUP function makes installing your TV/DVD easily...It leads you the Language selection, TV/CABLE selection and auto channel memory automatically...... Make sure that the antenna or cable TV system connection is made... ENTER CANCEL... Starting setup... Press POWER...The starting setup function begins and the Language setup menu appears on the screen...Press or to select your desired language, then press ENTER...... Users also looked at: Press or to select the “AUTO CH MEMORY”, then press...... 5S10101A [E] (P13-23) 23... This TV/DVD is equipped with a channel memory feature which allows channels to skip up or down to the next channel set into memory, skipping over unwanted channels...In addition to normal VHF and UHF channels, this TV/ DVD can receive up to 113 Cable TV channels...When shipped from the factory, this selection is in the CABLE position...... Press or to select “TV” or “CABLE...... Press MENU in the TV mode, then press to select option...... Cable TV chart... Press or to select “ADD” or “DELETE”, whichever function you want to perform...... The chart below is typical of many cable system channel allocations...... Press or to select “TV/CABLE...... Press press... TV/CABLE selection Automatic memory tuning... TV/CABLE AUTO CH MEMORY ADD/ DELETE... or... to select “ADD/DELETE”, then...
May 19, 2010 | Toshiba MD20F51 20 in. TV/DVD Combo
Language selection
you must go into the menue and set up wich is gona be hard because you are in another language but good thing is setup usualy the first menue selection once the main menue comes up then you gota figure out witch one says english snd hit enter
May 06, 2010 | Broksonic CTVG-5463GVC 19" TV
How do I change the language on my new J4580 machine
Thank you for using FixYa for your problem.
Try this;
Changing the language on the HP All-in-One displayFollow these steps to change the language on the All-in-One display.
  1. Press the Setup button (c01361401.gif).
  2. Use the arrow buttons (c01185108.jpgc01185072.jpg) to select Basic Settings, and then press OK.
  3. Use the arrow buttons (c01185108.jpgc01185072.jpg) to select Set Language, and then press OK.
  4. Use the arrow buttons (c01185108.jpgc01185072.jpg) to scroll through the language options until the preferred language is displayed.
  5. Press the numbers on the numeric keypad that correspond to the appropriate language displayed on the control panel display.
    NOTE: Ifa selection is not made within five seconds, the display automaticallychanges to show the next language. If a selection is not made withintwo minutes the setup menu exits and the language/region remainsunchanged.
  6. Confirm the language choice.
    • Press the number corresponding to Yes to confirm the selected language.
    • Press the number corresponding to No to select a different language.
  7. Aftera language is selected, a screen is displayed for region selection.Press the numbers on the numeric keypad that correspond to theappropriate region.
    NOTE: Ifa selection is not made within five seconds, the display automaticallychanges to show the next region. If a selection is not made within twominutes the setup menu exits and the language/region remains unchanged.
  8. Confirm the region choice.
    • Press the number corresponding to Yes to confirm the selected region.
    • Press the number corresponding to No to select a different region.
Please Rate my solution or reply for another answer if still not going
Richard Scott
Technical Support
Nov 18, 2009 | HP OfficeJet J4580 All-In-One Laser...
Philips TV stuck on the blue language selection screen.
unplug the TV from the wall outlet for two minutes, then try again
Nov 04, 2008 | Philips 32PT5441/37 32" TV
okay turn on your tom tom then touch he screen so the navigation menu comes up click change preferences then push the arrow key until the screen comes up with change language then select the language
Dec 25, 2007 | Tomtom GO 700 GPS Receiver
RCA HD52W59 HDTV Projection Television Logo
95 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
