If you mean BIOS startup menu, DEL or F1
if it's windows startup menu
for XP your computer restarts but before Windows launches, press F8
For Windows 7, follow this tutorial
Need to Start Windows 7 in Safe Mode Here How
For window 8 follow this tutorrial
5 Ways to Boot into Safe Mode in Windows 8 Windows 8 1
If you means something else by startup menu, please be more specific
SOURCE: i have already this message : press ESC to access Startup menu.
You should have the option to press either f2 or f12 to go in to bios
SOURCE: hewlett packard 6735s power up
Your battery is critically low. Didnt you recharge your battery? Try turning it on with the external power source connected.
SOURCE: I want to upgrade BIOS of my HP dv2718 notebook
Go to this page, select your operating system, and see if what is available for download there suits your needs.
Hope you are able to sort your problems out.
Regards,
Carlos
SOURCE: HP DV5T-1100 Laptop Machine will not
hi which one of these is yours ?
FL772AV, FQ866AV, FL774AV, FL773AV
SOURCE: i can't find my webcame
Most HP machines with a built in web cam mount the cam in the top center of the lid. Open the laptop and look at the area just above the screen in the center and you should see the lens.
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS
STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE
MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR
PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL
MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS
WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY
SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
To resolve this issue, create a BIOS administrator password and delete previous ProtectTools user logs by following this procedure:
Download and install the latest SSM utility (SP42536).
Softpaq Description
Information
Download
HP System Software ManagerVERSION: 2.10 Rev. A
SP42536 Instructions/Information
SP42536 File Download
Navigate to c:\Program Files\Hewlett Packard\SSM .
Access biosconfigutility.exe to reset the BIOS administrator password.
a. From a command prompt, navigate to the SSM folder.
b. Type biosconfigutility.exe to start the utility. A list of commands displays.
c. Type /newsetuppassword:"password" to create a new BIOS administrator password.
d. Close the command window.
Restart the notebook PC and press F10 at startup.
Log in using the new BIOS administrator password.
Choose User Management and delete any previous ProtectTools users.
Save the new settings and exit startup.
