Dishwashers Logo
M
MARIAN K Posted on May 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I USE WARM WARK WATER AND SOAP AND THERE ARE SMALL BLACK SPOTS ON THE WHITE INTERIOR
robert
Level 3:
  • Master 2,548 Answers
  • Posted on May 12, 2015
robert
Master
Level 3:
Answers
2548
Questions
0
Helped
869926
Points
8043
Put dishwasher on hot or sanitize. throw 1 cup of vinegar into bottom of dishwasher. put a bowl or cup with 1 cup of vinegar upright on the top rack. run a full cycle, but with no dishwasher detergent--just the vinegar. do this about two times a year. all will be well and black spots(possible mold/fungus) will be gone.(oh and be sure to clean out the bottom of the dishwasher's filter thoroughly before you do this)
3answers
How to clean white shoes properly?
Cleaning white shoes can help maintain their appearance and keep them looking fresh. Here's a step-by-step guide on how to clean white shoes properly:
Materials you'll need:
1. Mild soap or detergent
2. Soft brush or toothbrush
3. White vinegar or baking soda (optional)
4. Water
5. Clean cloth or sponge
6. Old newspapers or paper towels
Steps:
1. Remove Loose Dirt:
Knock your shoes together or use a brush to remove loose dirt and debris. You can also use a soft cloth to wipe away any surface dirt.
2. Remove Laces:
Take off the shoelaces. You can either clean them separately or replace them if they are too dirty or worn.
3. Pre-treat Stains:
If there are stubborn stains, pre-treat them with a mixture of water and a small amount of mild soap or detergent. You can also use a paste made from baking soda and water for tougher stains.
4. Soak Laces:
If you removed the laces, soak them in a mixture of warm water and mild soap. You can also add a bit of baking soda or white vinegar to help with stains. After soaking, scrub them with a brush or toothbrush, rinse, and let them air dry.
5. Wash Shoes:
Mix warm water with a small amount of mild soap or detergent. Use a soft brush or toothbrush to scrub the shoes gently. Pay extra attention to stained or dirty areas. Be careful not to use a brush with stiff bristles, as it may damage the shoe material.
6. Rinse Thoroughly:
Wipe off any soap or detergent with a clean, damp cloth or sponge. Make sure to remove all residue.
7. Dry Properly:
Stuff your shoes with crumpled newspaper or paper towels to help them retain their shape and absorb moisture. Let them air dry in a well-ventilated area. Avoid direct heat sources like radiators or sunlight, as this can cause the shoes to yellow.
8. Clean Soles:
Clean the soles of your shoes separately. You can use an old toothbrush or a small brush to scrub away dirt and grime. A mixture of water and mild soap or a specialized sole cleaner can be effective.
9. Protect and Maintain:
Consider applying a stain and water repellent spray to protect your white shoes from future stains. Regularly clean your shoes to prevent dirt buildup.
10. Polish (for Leather Shoes):
If your white shoes are made of leather, you can use a white shoe polish to restore their shine. Make sure to follow the instructions on the polish container.
Remember, prevention is key. Try to avoid wearing your white shoes in muddy or extremely dirty conditions, and clean them regularly to keep them looking their best.
Spots on wash
White soap powder spots can be caused by using the incorrect washing powder or else you are overloading the machine.
2helpful
How do I clean the washer to eliminate the dark spots of lint and dirt on laundry?
Prevent lint from clinging to clothes by adding 1/2 cup white distilled vinegar to the wash cycle.
To remove soap residue that makes black clothes look dull use white distilled vinegar in your final rinse.Get stained white socks and dingy dishcloths white again. Add 1 cup white distilled vinegar to a large pot of water, bring it to a rolling boil and drop in the articles. Let soak overnight. Some stains on clothing and linens can be soaked out using equal parts milk and white distilled vinegar.Before washing a mustard stain, dab with white distilled vinegar.ttack spaghetti, barbecue, or ketchup stains with a white distilled vinegar and water solution.Remove perspiration odor and stains on clothing, as well as those left by deodorants, by spraying full-strength white distilled vinegar on underarm and collar areas before tossing them into the washing machine.Forgot that you left wet laundry in the machine and it now smells moldy? Pour a few cups of white distilled vinegar in the machine and wash the clothes in hot water. Then run a normal cycle with detergent.Remove smoky odors from clothes by filling the bathtub with very hot water and 1 cup white distilled vinegar. Hang the garments above the steaming water and shut the door so the steam can penetrate the fibers.Keep the steam iron clean and in good working order by getting rid of mineral deposits in steam vents and spray nozzles. Fill the water chamber with a solution of equal parts white distilled vinegar and distilled water. Set it in an upright position and let it steam for about 5 minutes. When the iron is cool, rinse the tank with water, refill and shake water through the vents onto an old cloth. Test before using.Remove scorch marks from an iron by rubbing it with a warmed-up solution of equal parts white distilled vinegar and salt. If that doesn't work, use a cloth dampened with full-strength white distilled vinegar.Remove musky smells from cotton clothes by sprinkling them lightly with white distilled vinegar and then pressing them.Get water and salt stains off shoes and boots by wiping them down with a solution of equal parts white distilled vinegar and water.Give patent leather shoes and bags a better shine by wiping them down with white distilled vinegar.Get cleaner laundry! Add about 1/4 cup white distilled vinegar to the last rinse. The acid in white distilled vinegar is too mild to harm fabrics, yet strong enough to dissolve the alkalies in soaps and detergents. Besides removing soap, white distilled vinegar prevents yellowing, acts as a fabric softener and static cling reducer, and attacks mold and mildew.Eliminate manufacturing chemicals from new clothes by adding 1/2 cup white distilled vinegar to the water.Remove soap **** and clean the hoses of your washing machine with white distilled vinegar. Periodically run the machine with only a cup of white distilled vinegar in it-nothing else added to the wash cycle.Bring out bright colors by adding 1/2 cup white distilled vinegar to the rinse cycle.Fluff up wool or acrylic sweaters (hand- or machine-washed) and rid them of soap smell with 1/2 cup white distilled vinegar in the last rinse water.
Get rid of the tiny holes left along the hemline when you take out the hem of any garment by moistening a cloth with white distilled vinegar, placing it under the fabric and ironing.
I just washed a load of white towels they came out spotted with brown and black spots with a line of black goo at the water line machine is less than 3 years
your using to much soap, the collection has come off the rim of your stainless tub. by using a white cloth an cleaner you can wipe it off clean. the gasket <rubber seal> is probabbly that way too. you can buy affresh tablets an clean your washer weekly, follow the directions on the package.
you should be using 2 tablespoons of detergent per load. 1 tablespoon on delicates.
My water is black. is it now unsafe to use?
The question is why is it black? Is it mold or mildew? Has the unit every been cleaned and flushed regularly? If you answered NO, to the last question, that may be the problem. You can flush the system by using a 50/50 solution of White Vinegar and Bottled Distilled Water. After doing that, wash the interior of the water container with soap and water. Then run another flush cycle of Bottled Distilled Water. In the future, if this was the problem, use bottled distilled water only for humidifying purposes.
If the above was not the problem, there may possibly been some type of oil leak from the motor or one of the rubber gaskets is breaking down and polluting the water. Until you solve the problem, discontinue using the unit.
3helpful
2answers
I'm getting small orange spots/stains on my clothing after washing them in my Maytag washing machine. it is a 2010 machine too. Any thoughts as to what could be causing the stains?
Unless there is a child's crayon or something similar causing it, then suspect that the agitator shaft seal, or the drum seal is leaking oil into the drum. Hopefully, there is still warranty on the machine. Good luck!
Dish soap is leaving a build up on the interior of the dishwasher
Hi. Run your hottest and longest cycle with no soap, no dishes and 2 cups of white vinegar. Also, run the hot water into the sink before starting the dishwasher. Once the sink water is as hot as it gets, then push the start on the dishwasher. J.
1helpful
Green whites?
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Over loading the washer: Even if the agitator is suppose to go back and forth, the clothes are not. If you can hold the lid button on your washer so you can watch the clothes wash, they should 'roll" in the basket and not go back and forth like the agitator. The clothes will go down the side of the agitator, across the bottom of the basket, up the side of the basket and across the top of the water in a rolling motion. Overloading is not just too many clothes but also too little water for the size of the load is another way of having a overloaded wash load.
Water temp is important: Use a thermometer to test the temp of the incoming water in your washer. Hot water should be close to 140 degrees F. Warm water fill should be 100 degrees F. Cold water is approx 60-80 degrees F. What happens in a cold climate location is the cold water temp drops as the outside temps drops, once the water temp gets below 60 degrees F, it can no longer dissolve the soap properly and will most definitely leave "whiting" on the clothes!! Do not use a cold wash, wash your clothes in as warm as poss.  water as they can take. If you have delicates you want to wash in cold, start washer out with warm water as you are putting in the soap and fabric softener and clothes, then switch to cold to let it finish filling up, this will give you a warmer wash but not as cold as straight cold water. I find most washes can be done in a warm wash / cold rinse just fine. If you need ( and probably will ) to adjust your warm water fill, turn on the hot water tap fully, turn off the cold water tap. Let the water start to fill on a warm wash setting. Then slowly turn on the cold tap adding the cold water to the hot water making a warm fill....use a thermometer to set water temp and leave the taps stay when you get about 100 degree F water fill. I adjust my own washer usually twice a year, one on summer time and once in the dead of winter.
Test for too much soap or soap retention: Put in a load of towels or dark clothing that has been bad for the "whiting" problem. These items are bad for holding soap and getting what is called -soap retention-
Wash the load in the warmest poss. water, DO NOT add any soap. Let the washer fill with water and wash for approx. 5 minutes, lift the lid and observe what is on the top of the water. If you see soap and bubbles on top of the water, your clothes have soap retention, this soap came out of your clothes. Let the load finish with out adding any soap and wash all clothes effected with this "whiting" residue. Once all the soap is washed out of the fabric and you start to add some to each load, use about 1/2 of what the box says. Liquid soap has less problems with "whiting" than the powder does, but I find powder soap is better at getting my own personal clothes cleaner.
Small brown spots on whites
Top Dishwashers Experts
Mike Cairns
Mike Cairns
