Engines stopping at lights can sometimes be attributed to a vacuum leak in the brake booster
test by idling the engine with the hand brake on and no foot brake then apply the foot brake and if the engine dies then it is the brake booster
hard to restart may be the vacuum leak if you still have your foot on the brake.
SOURCE: engine died.won't start.
Sounds like your crank sensor is faulty.These engines are known for crank sensor and ingition control module problems
SOURCE: my car started dying and now hasnt enough charge to start
sound like bad battery cables.replace them.the positive battery cable is old and have a lot of resistance not allowing power to the alternator to charge battery.if battery cable good check alternator connector wires.make sure they are not damage also check alternator fuse and fuse link.turn off radio before removing battery wires so you wont lose radio code.
SOURCE: 2000 Plymouyh Grand Voyager Engine will not
did you check your battery charge, try a new one, check crank relay, check your starter, if cranking check your ignition system, check fuel , and maybe your immobilizer, go to proffesional tech
SOURCE: engine quit when stopped at
Sounds like the fuel pump is going out. Replace the filter first, as it's only $10. If that doesn't fix it, then it's probably the pump, which is $250.
