Question about Frigidaire FRS23R4A Side by Side Refrigerator
Water taste bad
It's a problem that's been escalating for a couple of days now but there is really bad tasting water coming from the fridge water. It's kinda a salty, rubbing alcohol taste.
  • STrendler Feb 05, 2009
    i have exact same problem, water taste is very salty, no other faucets in house have this taste. Filter is at end of life but cannot imagine it would make water taste like this
  • Cairn Noble May 07, 2013
    Where is the filter?
  • 44 Answers
Hello, does your unit have a water filter? Has this been replaced? If not I would remove the filter - flush the unit by dispensing as much water as you can to get fresh water into the system. Do you use the water much? Once you flush it, I would keep flushing it every time you get a chance for the next few days - without a filter in it and then replace the filter. Do you have well water or municipal water? Check the line in the back of the unit - anything unusual there? Good Luck, I hope some of these suggestions help you! Dr. Know
Posted on Dec 23, 2007
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
Water and ice have a funny taste
Try flushing out with bi carbonate of soda.
May 17, 2010 | KitchenAid KSRS25ILSS Side by Side...
Moldy taste from Whirlpool side by side
The problem can still be in your lines, or in the dispenser itself. If you run hot water with a little bit of vinegar in the lines and let it sit for about 30 minutes and then flush the whole system this should take care of your problem
Apr 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The ice and water from my refrigerator taste bad
run the water thr it for about 5 mintes and flush out theline.
Mar 09, 2009 | Refrigerators
Bad tasting water and ice from fridge and kitchen tap...
Hi!! change your copper line going to the icemaker and also install a water line filter you can buy one at homedepot easy to install and has instructions on how to...good luck..
Jan 05, 2009 | U-Line BI-95
Refrigerator water tastes bad after fridge was stored
Replacing the filter was a good idea, but you should also clean everything out as well.
Nov 30, 2008 | Maytag MBF2256H Bottom Freezer...
Bad water & ice cube taste
Hello redwood City
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water problem
if the lines are plastic then it has to do with your water supply line. is the supply a saddle type valve in your basement and is it connected to a copper pipe or a galvanized steel pipe?
Apr 30, 2007 | Whirlpool GS5SHAXN Side by Side...
Frigidaire FRS23R4A Side by Side Refrigerator Logo
378 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
