Question about Philips 170B4MG 17" LCD Monitor
Philips lcd monitor!!
When the main cpu if off the screen works fine, but displays "no input", but as soon as i turn the cpu on the monitor goes of magicly!!! i have tried checking the conections but nothing i have done has helped. i have even tried unpluging the screen, turning on the cpu and plugging the screen in, but as soon as the lead is conected the screen goes of (dont even get power to the screen)!!!!
can you help!?!
  • Loonatik Mar 08, 2008
    Intermittant problem. monitor inconsistantly goes black. have to switch off and on to correct. Once problem starts gets annoyingly worse and more frequent. Time for a new monitor? only 3 years old!
  • 1,605 Answers
Invest in a better monitor. Philip has never put out a good product.
Posted on Nov 05, 2008
No display, light goes green but on screen says no connection then goes yellow for standby tried both DVI and VGA so now linked my pc to my tele via DVI to HDMI and works fine anyone know what this could...
here is the simple test to detect hardware malfunction.
on every monitor these days whether its CRT or LCD already programmed inside self test.
detach your cable data to CPU and power on your monitor. if its displayed self test on your screen mean its OK and something wrong with your CPU, could be VGA error.
if its just black display mean some is wrong with your monitor.
if you post more detail maybe we in FIXYA could help.
Mar 11, 2011 | Hannspree HW191D LCD Monitor
Linking hp pc (windows vista) with philips lcd via a hdmi and dvi cable. When computer turned on and tv uned into hdmi channel i can view windows loading but screen goes black when it has loaded and screen...
You need to set your system to output to the port the TV is on.
If it is a laptop, there is an F key to change from LCD to LCD+VIDEO to VIDEO.
If it is a desktop you need to go into your display settings (control panel or rt clk desktop/properties or whatever system you have).
May 16, 2010 | HP Pavillion s7420n PC Desktop
Hello Sir, I am using DELL E173FP LCD monitor. My CPU absolutely fine I see initially booting thing on my monitor display then it gets black. I can hear starting sound of Windows XP, that too is fine. When...
You might need to change the screen refresh rate. Go do Control Panel> Display> Setting> Advance, choose 60 Hz. In order to make your Monitor able to display, restart the PC, press F8 on the keyboard frequently upon splashing ( 1 or 2 seconds after PC restarts). Select enable VGA mode by pressing up arrow of the keyboard> press enter. The display should look bigger, then you can start adjusting the screen refresh rate to 60 Hz
Apr 09, 2010 | Dell E173FP 17" LCD Monitor
Hp w1907 monitor does not detect any input and goes into sleep mode. checked wiring and connections -- looks normal. No trouble until today.
try to connect the monitor to another working PC, or to a laptop monitor socket, if it works there... then there is a prblem on you PC display driver or display card inside your PC, try to connect another working monitor to you trouble PC and check if that works.
Dec 07, 2009 | HP w1907 LCD Monitor
Using windows media XP warning comes up on screen-NO INPUT. Why?
update your video card driver or adjust your screen resolution and color bit
Dec 05, 2008 | Computers & Internet
Monitor problem
Hi, sandjkroll, this kind of problem could be because of ur monitor or even because of the on board display  card on ur motherboard. To check ur monitor, u unplg display cable which goes to ur cpu and the power cable which goes to ur cpu.
Them connect the power plug to mains, so no cable from the monitor should go to the CPU. Then u swithch on the the poower suply, and on the monitor. I
If ur monitor displays elongated screen still, and shows signal not found,and no display comes that means ur monitor needs to be send for service. and if there are no elongated screen and says no signal found, ur monitors fine, ur motherboad has a problem
Sep 28, 2008 | Microsoft ChiMei CMV938D 19" Widescreen...
Going to Sleep Displayed
I turned on my computer and the monitor displayed this message on the screen "going to sleep no input received". I checked the power cord and unplugged it, nothing. No lights are flashing or beeping sounds. The CPU is working just fine, anyone have any idea what to do
Aug 02, 2008 | HP vs19 (Silver) 19" LCD Monitor
VGA input not displaying
Hi, insert the monitor driver of screen on swicth reinstall driver in order to detect screen.
Jan 17, 2008 | Samsung SyncMaster 713BM 17" LCD Monitor
Dell E171FPb monitor turns on, but that's it
Hi Letneper,
Hope this will give you hints. Some monitors have standby mode or screen saver feature and or self test feature when not connected to video input of your PC or CPU. Except this problem did not occur at first use. You can turn this off like other monitors manually at OSD (on-screen display) settings if available. No more no less if it works fine with PC or CPU on then there's nothing to worry.
Best regards,
Rosener Guyano
Sep 04, 2007 | Dell E171FPb 17" Flat Panel LCD Monitor
Philips 170B4MG 17" LCD Monitor Logo
177 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
